Hello Kdj, does anything work if you just plug in from amp to "Amp In"? I mean, does the sub work with just that connection?
Does the Bi-amp terminal say "Bi Amp In"?
This is pretty confusing... I'm kind of thinking you might want to try the jumpers between the "To Satellite" terminals and the "Bi Amp In" terminals (if that's what they say). I'm imaging a jumper from the factory connecting the "To Sat" and "Bi Amp In" so it is all plug and play to start, requiring you then to disconnect the jumpers and do another connection to a second amp if you want to bi amp the sub. The lines on the bottom of the terminal cup might suggest that the "Amp IN' and "To Sat" are already connected, so maintain your "Amp In" connection as you've done.
Jim PA, do you see any problem, or any merit to this suggestion? In spite of my suggestion, I can't figure out in my head, or on paper, how the crossover is managing to split the signals between the sub and the satellites. My suggestion seems backward, and yours made perfect sense, except it doesn't explain what the "Bi Amp In" would do... "Bi Amp In" makes me think it should be getting a signal, thus the suggestion for the jumper between "To Sat" (that seems to be getting a signal) to "Bi Amp In".
Oh man, I hope you get them working! They are an awesome combo! I used to work at an Audio store in Michigan and we were a Fried dealer. I lusted after his sub/sat combos. Bud came in the store a few times to talk about his speakers and that was always a cool experience. Unfortunately I don't remember a hook-up like this specifically.
