JimPA
Distinguished Member
Maybe the series crossover makes sense here, and introducing a bi amp in there between the woofer and the mid (if that makes any sense). That way by adding jumpers between the "To Sat" and "Bi Amp" you can get the addition of the subwoofer. I am trying to picture how that would be wired but I believe it would mean that the satellites would always get a full signal, with out the benefit of a high pass at the woofer (to the sat).
I gather you, JimPA, are thinking that if Kdj hooks up the amp to the Bi Amp In, maybe you just get bass from the sub?
Rick you have to remember mine were built from a kit.
My subwoofer only plays the low frequencies.
I purposely used the jumper since it came with the terminals.
I know my satellites are being crossed over since I was the one that built the crossover.
I have built several pairs of subwoofers this way.
I did things this way since I wasn't going to wire the crossover in the parallel configuration.
I had no reason to use a bi amp terminal plate.
The later models of the Fried subwoofers didn't use a bi amp terminal plate since they all used a series crossover.
