Function lights dead on 2240
Batan
The function bulbs on my Marantz 2230 are dead as well as the stereo indicator. The main tuner/meter lights are fine, I just upgraded them to LEDs. Is there a common fuse for function lights?
If you don't see a board with several glass fuses inside the unit, it probably doesn't have a fuse for these bulbs. Fuse boards are mostly in international units. Most likely, if the function bulbs worked before the LED upgrade, a wire got broken or a short was made on the function light board. It looks like the power to the function board comes through the meter lamps. Look for a broken wire on the back of the meter lamps, or a pinched wire in the same area, since you had to remove some screws and a panel and put it back together.
Thank you. Steven. Actually, yes, there is a board with fuses. (This is a Canadian Marantz) They looked ok but I used haven't checked. I thought it would be somewhere else. I'm assuming it's the 0.5A fuse for this?
The bulbs did not work before the swap, either. I will be getting back into it to me investigate as well as to go fiddle with the colour of the bulbs.
+1
See above.
Visually, yes. But that's as far as I got inspecting it. Foolishly I thought a smallismall fuse for this would be elsewhere, if it even existed.
Well be sure to ohm it out with a DMM. And if it is intact, then you need to trace to where the voltage stops.
