Fuse Protecting multiple speakers
I thought I tried that. Unless I am a complete idiot and did not switch the listening to cd and record to tape when I was in the zone could happen. hmmmm. The adcom GTP 500 allows you to record from other sources than the one you have selected. IE I hooked my signal up to the CD in. I could however at the same time be playing a record and while listening to the music on the cd input, I can record what is playing on the record at the same time. Let me read documentation again. I included the page. I am willing to try again. Lots of wires back there. :). Is there anything wrong with splitting it at the main norm out?
Ahhh, Yes, your Adcom is most unusual. You have to two selectors! One for 'listening' - this is the source you want to hear on the PL amp. Other selector is for Recording - this is the source sent to the Tape Out. Just make sure you have the Record Selector set to the source you want to send to the Kenwood.
Yes, it would be a bad idea to split the main out. This would make a mess of your volume controls and you'd have tone controls in tandem. In short, you'd be putting the signal through two pre-amps and that's always a bad idea.
By connecting the way I recommend (Tape Out on Adcom to Aux IN on Kenwood) you can play the same signal on all of your speakers regardless of source. That is, suppose you wanted to listen to vinyl or FM. You only have to connect your TT to the Adcom and the signal would also be available on the Kenwood. (You must Record Select phono and listen select phono in this case, however.)
Regards,
Jerry
I will try it again. I will let you know. Like I said I am sure I checked. Its a worm den back there and it was late. Cheers.
You know, I just got to thinking: What kind of speakers would God have?
And then, it occurred to me: God doesn't need speakers. He's already got Mozart, Caruso, Joplin, Hendrix, Pavaratti, Horrowitz and all of the dead greats for a live performance any time he wants. He's probably letting the Rolling Stones live as long as he has, despite their best efforts to join him, because he can't stand Mick Jagger.
I'll bet Ham, Shem and Japeth are headed to God's place tonight for a bit of Buddy Rich and Maynard Ferguson live (in the performing sense) on the back patio.
Don't be so condescending, he probably already learned that in the 5th grade.
