Fuzzbuster
Addicted Member
I read some consumer reviews about the Synergistics Blue fuses with amused skepticism. One person said they "transformed" his system. How can a fuse have any effect on sound quality? It seems like they're $150 snake oil.
Technically, they'll have no effect on acoustics -- at least none that has any basis in known electronics or physics.I read some consumer reviews about the Synergistics Blue fuses with amused skepticism. One person said they "transformed" his system. How can a fuse have any effect on sound quality? It seems like they're $150 snake oil.
OMG. Stay away from 'The Absolute Sound'.I read some consumer reviews about the Synergistics Blue fuses with amused skepticism. One person said they "transformed" his system. How can a fuse have any effect on sound quality? It seems like they're $150 snake oil.
Excellent. My purpose is fulfilled.Okay Dave, you owe me at least a roll of paper towels and possibly a new key board for my laptop and a replacement cup of coffee.
However, they may have a psychoacoustic effect. Perception of sound is the result of a complex interplay between physical hearing and cognition or mental state, which means that believing the fuses will transform the sound -- or even being skeptical that they'll transform the sound but remaining open-minded enough to try them -- can result in a perception that they've transformed the sound.
At least that you know of...Technically, they'll have no effect on acoustics -- at least none that has any basis in known electronics or physics.
Unless appropriate experimental controls are implemented, how do you know whether the perceived sound difference is due to an acoustic difference or a psychoacoustic effect?There you have it. We can't measure it because we don't have the technology to do so. One day, sometime in the future we will be able to follow the electrons through a conductor and learn more about how different conductors affect the transmission of an electrical signal. We don't know everything, we can't measure everything otherwise the advancement of science would come to a screeching halt.
There are some that can hear the difference. There are lots, most AKers, that can't.
Because some people have better hearing than experimental controls do. Did you see that we don't know everything yet?Unless appropriate experimental controls are implemented, how do you know whether the perceived sound difference is due to an acoustic difference or a psychoacoustic effect?
Instead of employing amateur speculative omniscience, why not ask Wilson Audio why that is a deliberate aspect of their design?There you have it. We can't measure it because we don't have the technology to do so.
If you're aware of physical/electronic effects due to changing a fuse that would cause a sonic effect, please provide a link.At least that you know of...
How do you know it was an acoustic change as opposed to a psychoacoustic effect?Years ago, I bypassed the signal fuse in a pair of Acoustat 2+2s and I can assure you it most certainly had an audible effect!
A fuse is electrically a low power rated resistor of very low resistance. Small, low-value resistors also make good fuses, particularly if also used to provide level matching as described on page 43.Note that Wilson Audio loudspeakers use low power rated resistors in their crossovers to serve as fuses - avoiding the insertion of one into the signal path. Refer to page 43.
What is the evidence of this?Because some people have better hearing that experimental controls do.
That is true, but suggestion of an unknown effect is not evidence of an unknown effect.Did you see that we don't know everything yet?
Loudspeaker companies most certainly don't publish their research which can impact competitiveness in the market.If you're aware of physical/electronic effects due to changing a fuse that would cause a sonic effect, please provide a link.
