You appear to have misunderstood my reference. I was pointing out that in the roughly 200 year history of electronics, we have not yet found factors outside of resistance, inductance, and capacitance to explain the behaviour of electronic circuits. Thus, we have not yet found an electronic factor to explain why changing a fuse causes a change in sound.How many more empty logical fallacies are you going to invoke? Gross, unsupported speculation on your part doesn't help either. Tell us again about listening tests in the nineteenth century.
Yes. Why do you think they use blind testing?Magnepan is a great example. Their "dot seven" series resulted from blind testing.
I'm sure that's true.They couldn't care less about what anonymous internet amateurs *believe*.
Of course we have! EMI/RFI shielding/resistance most certainly makes a difference! Is that outside your experience, too? Ask Belden why they shield a wide range of cables. What exactly is the metric for quantifying its efficacy? In this case, however, I suspect the answer is simply RLC based with the complex amplifier-speaker interface.You appear to have misunderstood my reference. I was pointing out that in the roughly 200 year history of electronics, we have not yet found factors outside of resistance, inductance, and capacitance to explain the behaviour of electronic circuits. Thus, we have not yet found an electronic factor to explain why changing a fuse causes a change in sound.
If you want to spend that kind of money on a fuse, that might blow a week after installing it. Have a nut. It is your money. Personally, I think its ..well .. a total waste of money.
It may help you lose weight. In your wallet.![]()
And whilst we're still here...
What a tremendous non-answer.Parroting what you think to be science is all you. At the expense of confusing the issue with facts, you haven't demonstrated anything to support your claims. Just predictable logical fallacies.
Have a great day, Dave. Perhaps you'll find other things to scratch your chin, look at the ceiling and speculate about.![]()
Noise is an external or generated factor rather than a fundamental parameter. Are you claiming the special fuse sounds different because it's shielded?Of course we have! EMI/RFI shielding/resistance most certainly makes a difference! Is that outside your experience, too? Ask Belden why they shield a wide range of cables. What exactly is the metric for quantifying its efficacy? In this case, however, I suspect the answer is simply RLC based with the complex amplifier-speaker interface.
Just responding to your overtly incorrect statement.Noise is an external or generated factor rather than a fundamental parameter. Are you claiming the special fuse sounds different because it's shielded?
My statement was correct. The three fundamental factors or parameters of all electronic circuits are resistance, inductance, and capacitance. Any passive circuit can be constructed from combinations of resistance, inductance, and capacitance. Circuits are not constructed from combinations of resistance, inductance, capacitance, and noise. Circuits may generate or be affected by noise, but they are not constructed from it.Just responding to your overly incorrect statement.
Yes. That speaker wires have sufficient resistance, inductance and capacitance to affect acoustics is largely accepted, and demonstrable with appropriate test equipment.You continue to miss the point about amplifier-cable interaction. Did you follow the provided link?
Such requires empirical experimentation.Just because there may be a difference in the performance zip cord at audio frequencies does not automatically mean that different power fuses fuses will cause differences in audio signal quality. They may or they may not, but the logic does not mean that they must.
And the speculative ramblings of non-experiential theorists is ignored.
Then compare the two for a difference.
From serious consideration. Sorry, but speculation doesn't change my empirical experience.How so? If you had ignored me, you would not have replied.
Kindly quote anything I've posted and I'll be happy to respond.Your usual rap of; "only if people were as smart as the people that design expensive tiny items, the world would be better"
In the real world, the expense of *publishing* data about product knowledge makes zero financial sense.Either they really dont have such studies, or they dont like what the studies show, so they wont publish. Which is it?
Empirical experience consisting of no more than "I heard it!" or "We heard it!" can't be considered reliable unless cognition (what you know) is separated from acoustics (the sound that enters your ears) so that cognition can't bias your perception of sound.Sorry, but speculation doesn't change my empirical experience.
Engineers don't waste their time writing dissertations of product advancements. They spend their time working on product advancements.It costs ZERO to put a link up on the internet.
In the real world, companies typically rush to publish results in white papers and scientific journals because it generates investment and further discoveries. For obvious commercial reasons, sometimes specific details are elided, but the essential discoveries are proudly announced at no cost to the authors. Scientific journals, magazines, Web sites, etc. typically bear the cost of publication because interesting and valuable discoveries help sell journal subscriptions.In the real world, the expense of *publishing* data about product knowledge makes zero financial sense.
