ginovino
vintagestereo said:I'm no expert, but you can clearly tell that the G-9700 clearly does not have th Dual Power Supply that distinguished all the truly great receivers. There are only 2 Filter Capactors instead of 4. That's clearly a step down and certainly explains some of the weight loss. On a more trivial note, the G-9000 has a handly little metal strip running along the bottom on each side to tuck in the wires protruding from the side-mounted connectors. I notice that the G-9700 dispenses with that as well.
However, it will be of GREAT interest to see if EW has a preference, although I suspect what it will be.
You are absolutely right on all counts. There are only 2 caps in G9700 of 12k each... certainly not a currrent monster.. whereas the G9000(G901) has that monster Torodial with Sansui all over it and that side rail of some value.
I have more cap (60k) in my Kenwood Kr-9050 @ 160watts then the G9700 has @200wpc!!!!
