enginedr
You feel battery power in turbo is better than Direct mode with the battery off? Not so over here. I have tons of slam as well.
When the IFI micro DSD is set on direct it by passes the volume control .
When put on turbo mode it runs only on battery power and will not charge unless you turn it off . In normal mode it runs on usb power only and does not charge the battery . In econo mode it runs on usb power and charges the battery at the same time . My point is the battery has more current available to
The unit then the iusb does . The test. Is if it has more slam on battery .
I feel the iusb Is a little light on the power . I hope the REGEN with a good power
Supply will make it more lively .
_oh
Its well known across different types of electronics and circles what a dedicated PSU can bring to the table. So im with you there.:yes: But im not missing any slam as is....the better dedicted PSU will add and enhance the music while doing a better job.
