Vinylmasters
I have three headshells for my Technics SL-3300. One of them has a p-mount adapter, makes it real easy to change out cartridges.
Not when it's a Grado.
OK! New Grado Black2 in the house!
First impressions: Grado STILL sucks. Sounds dead as a doornail. NO 'air', almost muffled and muted.
Anyone wanna buy a slightly used Grado? This is just as crappy as the last series was.
That's the same experience I have with their carts. Dead, dull and no crisp upper end to speak of. And, I've tried my Black1 on several turntables. It sits in a box now.
I dont own a black just blue 2 and gold 2 and a couple of woodies and a vintage Grado with dc resistance of 800 ohms. The older Grado ie not the vintage one but the gold 1 etc which had 400 something ohm dc resistance were not exciting, the new blue 2 and gold 2 are far nicer at the top end and very wide dc resistance 680 ohms despite what is written on the instructions. The old vintage 800 ohms is exciting to listen to also so looks like Grado is going back to higher dc resistance.OK! New Grado Black2 in the house!
Grado though are still high compliance so I do wonder if those who find them muted or unexciting are listening to them on an arm which is not correct compliance for the cart?
Also depends what you are comparing them to. I think the sound of the blue 2 and gold 2 is very natural ie nothing accentuated ie treble level correct mids correct and deep nice bass. If someone likes accentuated highs like the old AT95e and quite a few other carts they are not going to like a Grado. Old Grado were a bit rolled off up the top, but dont believe the new ones are at all.
Chris
Your arm on at least the sl1301 is too heavy I did not check the rest. I use a Technics sl1210mk2 modded and with an oil damper on the arm which extends the compliance, without it the Grado would be way outside its happy place, even with the damper it is just in. Depends what you are looking for too, if you are looking for accentuated treble which is a lot of carts then you wont find this is a Grado. If you want it to sound as it was meant then you will be a lot more happy with the Grado. Shures apart the M97xe are hot in the Treble for example.All I can say is this: I've had various Grado's on a SL-1301 (that was this one), a JVC QL-Y55f and an old Onkyo table I can't remember the model # of, and they all sounded the same on each on of them (I believe all went through a Yamaha M-70 with a Yamaha C-70 pre). I can compare them easily with a p-mount setup that I have - all kinds of AT's, ADC, Empire, Pickering, Stanton, Shures from conical to ML's and a couple SAS as well. Even my Red Ed runs circles around this Grado. I have yet to figure out why so many are enamored with them.
Decca for what it is worth was considered hard to set up and fussy of arms, not so with new ones, the issues were older ones with loose tie backs which made them almost impossible to get working. Old ones serviced or new and they work on any arm with is the right compliance. Decca (mine is a super gold) IMO is the best cart I have ever heard, all else is just a recording they are the live performance.The strong suit of the Grados in general was a fluid natural midrange response. More money moving up the line brought refinements with extensions of performance up and down the audio spectrum.
Like the Decca London, it's a brilliant if quirky device.
Chris
A good well set up Grado on a decent system will give amazing results, but nothing beats a Decca.
Chris
something is wrong someplace. There's usually not much that will play the midrange like a grado, or the upper grace carts.Honestly. I don't see (or hear) that at all. I hear 'mud'. No 'brilliance' at all to it. Just 'mud'.
They typically aren't masters of detailing, like MC carts and some MM-MI with line contact tips.Honestly. I don't see (or hear) that at all. I hear 'mud'. No 'brilliance' at all to it. Just 'mud'.
System matching, a compatible turntable setup, and in my case a hearing test for mid to hf acuity was instructive.
Chris
