As for speakers, it is difficult to recommend as they really differ in sound charcter and you have to add you preferences in the formula. That said there are some safe bets for starters but, every vintage speaker unless you are VERY lucky requires some TLC to get up and running well usually refoaming if surrounds are foam and sometimes caps on the x-over.
If you like pricipally jazz, easy rock, classical, vocals than depending on your room size look for either a pair of the original Advents (labeled "The Advent Loudspeaker") or The Smaller Advent. These usually require refoaming unless redone already. Also, well liked are KLH 6s, AR 2 or 5 series. A/D/S L-x10 and early L-x00 unit (x = some number, i.e. 2, 3, 4 etc). Many of the models have butyl surrounds so no refoaming issues. I also, favor U.K. vintage speakers from Goodmans, Tannoy and Wharfedale. The Wharfedale W series including the series with no suffix and the series with the D suffix seem widely appreciated. Wharfedale was an early adoptor of foam and also pretty quick to drop it so many of its speakers do not have the isue but most seem to need recapping which is not difficult or expensive.
I've had my Wharfedales on the larger H-K 630 and the mating is very good; good synergy from the pairing.
Also, another personal preference that shou work well would be the Bozak 302a. Again from personal knowledge with the 630, a wonderful pairing.
Remember in any given year during the vintage period there were mode manufacturers of speakers than all other audio manufcturers combined so there are many sleepers out there.
The key for starting is IMHO, local pickup, ability to check there operational condition and if possible from the owner so you can determine the abuse they have had. Many times, there can be an added benefit since possibly the entire vintage system is for sale though maybe not advertised or a record collection.
Another speaker that does icely but sounds very diffeent from the above is the Klipsch Heresy and Cornwall. Klipsch lovers seem to single out the x30 series receivers as favorites. Other vintage Klipsch would include the Chorus and Forte.
