Will check it again tomorrow. I did check C11 and there is no voltage across the pins.Let's go down the list:
- "Fuses have continuity." -- Good
- "C3 and C4 measuring 23.5v DC." -- Good
- "When measuring IC1 and Q5 I use DC with black lead to chassis correct?" -- Yes, black to chassis. Pin 1 = Input, Pin 2 = Output, Pin 3 = GND (chassis)
- View attachment 3006244
- "When measuring C11 I measure dc red to + and blk to - correct?" -- Yes, red to (+) black to (-). This should be the same as the regulator (IC1) output voltage, 12.1VDC.
- "Still no readings from the transistors with bk to chassis ground and using + probe to transistor legs." --
- Pin 2 of IC1 (previous measurement was 21V) should be the same as C11 (+) and Q5 collector?
- If not, look for a break in the PCB trace. You can turn off power and use ohms to check continuity from IC1, pin 2 (see diagram above) to C11 (+), to Q5 collector.
