I’ve been working on this amp periodically, I stepped away for just a little bit to give me peace of mind. It was driving me bonkers. I’ve been working on it for a little while. The first thing I addressed was the major hum when plugging in any type of source. I rewired it exactly how it was when I got it. So the person that wired it previously did have any of the. RCA sleeves grounded. I checked my photos of those RCA‘s prior to me doing any work on it and sure enough I don’t see any connection to ground. Immediately took care of the problem.
I hooked up a signal generator into an input, hooked up a pair of 8 ohm drivers, and an oscilloscope across those drivers. All pieces of test equipment I was using have isolated grounds just in case, so either battery powered or run off of a small DC power supply. Bought this oscilloscope specifically for this lol. Hooked up a CD player, and I was getting audio from both channels, but it’s still did not sound right. So I went to make adjustments on the amplifier input level adjustments.
The right channel adjustment would adjust both channels, one more than the other. The left channel adjustment would do very little to either channel. I got the two channels to be fairly even.
Here you can see me adjusting the
level adjustment, one channel would increase and decrease at a faster rate than the other.
I didn’t know what was going on, a lightbulb went off in my head. I decided to hook up only one channel input at a time. So only had an input in the right channel and then disconnected and hooked up the left channel. That’s what I found. I was getting output from both channels when only the right channel input was connected.
With the input going into the left channel was getting no output at all.
I will say that I am far more accustomed to solid state than tube and its outputs transformers, so I don’t know if this is normal or not, but doesn’t seem like it would be. Measured the resistance from the left channel 8 ohm tap to the right channel 8 ohm tap and I’m seeing a little over 1.5 ohm. So the two channel outputs are shorted together.
This amp is a mess. Is this reading normal? I’m just looking for pointers on where to go. One of the next things I’m going to do is insert a signal into both channels, but at different frequencies and then see if I’m getting two separate signals going to the. Level adjustment pots. If I’m getting two separate signals to that point, then I know the issue was isolated to the amplifier board. This amplifier has proved itself to be nothing but a nightmare lol. I would greatly appreciate any assistance that could be provided, so far you guys have provided much.
Thank you again,
Dan
