The electrodynamic or field coil speaker is something that can be replaced with an AlNiCo speaker, the field coil was usually part of the filtering for B voltages. And in place of the coil, a resistor of adequate wattage and usually about 350 Ohms to replace the coil.
There is value in the tubes, the output transformer, the power transformer. and controls. But to someone who needs those pieces you have intact- they are probably worth more than the sum of the useful parts. As you can see in Gadgets' picture, the cabinet makes for a handsome looking unit. You never know- you might want to hang onto those parts you have because you may stumble across a decent cabinet tomorrow, next month, or next week. You just never know.
