Audio Deacon
Crap or not they do have my interest.
Yeah me too man. I'm hoping someone gets on here and say's I have a pair of those and they are .....
Ok Passive is good but why are they so heavy and what are there two sets of connectors? Have you seen any like these before and do you know the maker?
Ok I'll be honest. I see alot of crap speakers from the 70's. I know what poor RCA jacked speakers feel like and they usually don't weigh 40 pounds each. Furthermore most speakers built in that era which offered RCA's as the input, didn't offer connector cable inputs as well much less two sets of connectors. I hope to discover what they are soon. Eventually we'll hook them up and let AK know about sound and performance.
The two RCA jacks suggests they could be stereo speakers, both left and right in one box. Either that, or they were meant for bi-amping (But I doubt that). The low height suggests they were meant to be set up on tables (they look too deep for bookshelves). I suppose they could be placed under a TV set for use as external speakers. I don't see how they could be active/amplified if there is no AC power plug.
My apologies. Get that screwdriver baby!
Could these have been part of a quad system? What with the dual inputs per enclosure.
Biggles
It was very common for speakers (often cheaper speakers, FYI) to have both screw terminals AND an rca-style connection. The rca connection made sure the consumer didn't accidentally hook up the speakers out of phase, and it made putting everything together very simple. Realistic, KLH, Panasonic... really a ton of companies used them during that era. It's not a definite red flag (as the klh model twenty and some of the Realistic models sound quite nice), but it's much more rare to see the rca option on high end models.
I concede and agree that these absolutely come from the era where this type of hook up was common. And maybe they're "Realistics" or Big Box Store (JC Penney's, Montgomery Wards, Sears, Fedco, Two Guys, J.J. Newbury's... lol ) type speakers, I don't know. But I wanna know. And I can't freakin dismantle them!!!:tears: I've taken off every screw and removed every bolt and Nothing Moves!!! The panel doesn't lift... The backplate doesn't slide... NOTHING!!! This is Freaking Killing me. For Goodness Sake! Somebody tell me what they are!!!
Thanks Guys. Can you feel my frustration.
Just a thought seeing the feet, will the bottom come off with the feet? There is a cap nut looks like it goes through the rubber foot on both sides, is there a big screw thru the front ones also?
I have a couple of pairs of speakers with grills that would not come off. After close examination, I found small screws buried in the grill cloth in the corners. The screws are painted to match the grill cloth and are difficult to see even though I know they are there.
Use a strong flashlight to carefully check the corners of the grills to see if there are any small screws hidden in the grill cloth. If you can get the grills off there might be an obvious way to get inside to look at the drivers.
Everything comes apart. Well, except tome early KLH speakers. Is it possible those are some type of PA speakers from someplace like a church? What direction do the speakers fire, front, side, both?
I have no clue what they are.
They were NOT cheap to produce. The cabinet appears to be cast aluminum or at least the narrow portions of it, and the cast has been painted adding at least 3 more steps to the production process. Also appears steps were taken to ensure an air-tight seal.
I think the rubber bumpers on the rear edges were there to stand them off from a wall in that placement scenario.
I kind of get a vibe that they might have been the treble element in a 4 piece speaker system. :scratch2:
