Help with hookup sansui reverb bose speakers
Miketoole
I have a fisher quad reciever and a sansui reverb. I think the bose e.g goes into the tape loop. But the sansui reverb does too. . what do I do to hook both up . thanks for any help
The Bose EQ should provide a tape monitor loop to replace the one it uses. Which model is it? Got pics?
You have that wired incorrectly. Keep the wires as they are on the EQ side. The red and black connectors should go to the OUT TO RECORDER Front Left and Right jacks on your receiver. Connect a cable from the TAPE RECORDER CONNECTIONS OUTPUT on the EQ to the REVERVERATION IN. REVERBERATION OUT goes to the TAPE RECORDER CONNECTIONS on the EQ. Keep the TAPE switch on the EQ in the monitor position, and use the REVERB switch on the reverb to enable or disable it. If you have a tape deck it can be hooked to the appropriate jacks on the reverb.
