I don't see any electrical loading details to accompany the frequency response curve in that Hi-Fi News article.
The article refers to the MasterTracker with Micro-Line stylus but the OP is interested in the StudioTracker with elliptical stylus. This description of the sound by MoFi doesn't sound very 'Audio Technica' to me...
"StudioTracker offers surprising bang-for-your-buck value and a rich sound distinguished with a smooth, slightly forgiving top end"
Thanks for your input mate.The effective mass of your JVC tonearm is not listed in the manual. My experience with a similar JVC arm from that era suggests it is on the slightly heavier side of medium mass, e.g. 15g-18g depending on the model. The headshell used will also affect things. Typically these arms come with a lightweight headshell.
The Master Tracker was measured by HFN to have a compliance of 13 CU. As such it would likely work fine on that arm, though I would pay attention to the weight of the cartridge as these are on the heavy side, and I'm not sure if your JVC includes an aux counterweight for heavier cartridges and headshells. You can end up with a situation where the counterweight is way on the back of the arm, not making full contact with the stub.
https://hifinews.com/content/mofi-ultradeckm-turntable-package-mastertracker
I wouldn't recommend the MOFI carts though, they are just re-badged AT carts with an extra shell around the generator and jacked up prices. They also glue the stylus assembly in so you can't change it - probably because they want you to buy another one instead of just getting a new stylus. If you want an AT cart, go to the source.
Forgiving top end is one of the reasons I got interested in it, and crossing my fingers it will be so.I don't see any electrical loading details to accompany the frequency response curve in that Hi-Fi News article.
Forgiving top end is one of the reasons I got interested in it, and crossing my fingers it will be so.![]()
I will be intrigued to learn the outcome - please post your impressions.Forgiving top end is one of the reasons I got interested in it, and crossing my fingers it will be so.![]()
You bet, as soon as it is hooked up I will give my impression.I will be intrigued to learn the outcome - please post your impressions.
I got the cart for 60$ so I thought it was worth a go
I installed it and as you say you have to move the counterweight back, but mine seems to be pretty heavy since it is still making full contact, with 2g of pressure. So now I just need to get the connections for the headshell so I can give it a testrun![]()
Yep, but this one is basicly new since the guy who sold it upgraded to the Master Tracker before even trying this one out (that came with the TT). So it should be good to go, but you never knowWell $60 is pretty cheap. I assume you bought it second hand? As you may know, the only real way to check for stylus wear is under a high power microscope with good focus and lighting from the correct angle.
Apperantly MoFi colaborated with AT and developed cartridges to their specifications, what that means I do not know, but I guess it has some sauce to it that you might not find in other ATs. I have gotten it explained to me that it is def. not just an OEM version of other carts.Interesting that it's smoother than the AT-VM530EN, or rather that you found the 530 harsh. I have an AT120E which was the predecessor of the 530 and love it. I wouldn't describe it as harsh but this might be because I keep the load capacitance down. If the StudioTracker is made by AT, perhaps it sounds more like their AT-VM95 cartridges.
