I can't recall- are the D2 dustcovers twin slot for the hinges or single slot for the hinges?
If twin slot, you can buy new SL-1200 hinges from KAB that will work.
Cool, so maybe a new set of sl-1200 hinges would work then?
I think I may try buying a set of SL1200 hinges, and adapting them. However, I also know that the 1200 covers are bigger and therefore heavier, so I'm not sure if the cover, once adapted will stay down!Anyone know where I can get hinges for a Technics SL-D2?
Looking for a solution too!I have an SL-D2 as well whose hinges are now so weak, they're useless holding up the cover. Can anyone source replacement hinges (that are strong enough to keep the cover up) or suggest novel work arounds? Thanks
Michael
I have exactly the same issue. I am wondering if it is not possible to tighten them in a way?I have an SL-D2 as well whose hinges are now so weak, they're useless holding up the cover. Can anyone source replacement hinges (that are strong enough to keep the cover up) or suggest novel work arounds? Thanks
Michael
