Hi AK - I sure hope someone can help me fix this deck. At first, I thought the tape eating was a bad pinch roller, then I suspected belts, dreading what I've read is an extremely difficult job to rebelt this deck.
But upon disassembly, roller as well as belts look ok. But clearly the rubber on the secondary motor clutch and adjacent idler wheel are shot.
But here's where I am confused, looking at the photo of these, you can see two round rubber orings, one has snapped. But this surely isn't the original rubber right? I would expect a square tire? Or would there have been no tire at all, and instead the adjacent idler wheel tire fits in the clutch slot? I'm almost thinking the idler wheel tire wore down, then instead of replacing, someone just hacked a work around by putting these two orings around the clutch to make contact with the adjacent worn idler tire?
Unfortunately, the service manual I have is not helpful in that it does not even show the idler wheel or tire in the cassette mechanism parts diagram? It does show the clutch, but does not indicate whether or not it has a rubber tire around the spindle? Surely not 2 orings!?
Making things more challenging is that while I do find idler tires for the very close one year newer cd 491, I cannot find idler tires for the 401?
Can anyone tell me if they are the same? Other source for original 401 tire?
Will the readily available nakamichi sankyo transport tires work? I did read over at tapeheads that they may be the same.
Can anyone confirm whether or not there is a separate rubber tire on the clutch?
I would really appreciate it if someone can help me get this fabulous sounding deck fixed right. Thank you.
