Whoah !!! After 36 years of DHT amp building, in 2018, I would not use the AWGs you are thinking of, at all. One must maintain high transfer efficiency, inside the SET amp !!. Or else it will be boring dynamically, like most all tube amps today are. Most of the wire I DIY-use is m22759/11, look it up.
I use 12 AWG on the primary leads of the Power Transformer, and to the AC switching and fuses. 20 Amp Hubbell IECs, no 15 A. ones. On the Power Transformer Secondary, I use 16 AWG on the ENDS of the HV secondary, UNTWISTED to the tube rectifier,....( sounds better untwisted ) and 12 AWG as the HV winding's center tap lead-out to star ground. My 5 VCT ( 5U4GB or 5V43A ) rectifier winding is 14 AWG on ends, and the rectifier center tap, feeding the B+ filter, gets doubled-up 14 AWG ( effectively 11 AWG ) to L1. L1 and L2 are usually the same size and value. I always replace stock Hammond choke lead-outs with doubled up 14 AWG . In 2018, I favor Hammond Ls such as the 159ZB ( 7.8 Ohms ) and the 159ZA ( 6 Ohms ) for monoblocks using 2A3 Finals, etc etc.
The B+ filter, is almost always ( 5U4GB, 5V3A ) directly heated rectifiers that can do 4.6 A. and 6.6 A. instantaneous. L1 as above, C1 is a WIMA DC LINK 4 Pin up to about 35 uF total / maximum , L2 as above, and C2 is typically about 50 to 56 uF as a total "C" amount. Maybe a 50 uF WIMA DC LINK MKP4 and several paralleled film caps, to get precisely what I want, aurally from the filter ( wide band response and superb Dynamic contrasting are my main build goals.)
At the C1 and C2 filter location ( to my DHT Finals ), I bypass these two main caps with a 5 uF film cap that is rated at / shows an " I Max" or maximum current capability of 1570 Amperes. In these A1 circuits, this is KILLER for getting the
leading edge of all musical transients, like no one has ever heard before in the tube audio universe. Same caps are in my speaker crossover - VOTT a7-800s., Now, this cap type, and my specific use of heavier m22759/11 wideband wire must make some sense to you.
Have fun, I do.
Dowto1000
OK, have I given you enough to digest?? Have fun, I do. Did you see this post from yesterday, of mine ??
http://audiokarma.org/forums/index....leads-of-audiotransformers-and-chokes.824731/
