How many watts is your Amplifier @8ohms
How Many Watts is Your Amplifier @8 ohms
  • Total voters
    426
Main living room - Peachtree Decco 2 (MOSFET) - 40 wpc @ 8 ohms
Office - Monarchy SM 70 (MOSFET/Class A) - 25 wpc @ 8ohms
Main system - Emotiva UPA-200 (Class A/B) - 125 wpc @ 8 ohms
No flaming if these figures aren't exact...I think that's right though...too lazy to look it up, lol.
Kenwood KR 850 75 wpc @8 ohms .01 THD 20 Hz to 20 kHz
Kenwood KR 4600 30 wpc @ 8 ohms .5 THD 20 Hz to 50 kHz
Sony HT 100 wpc
I use Polk TSx 110s (90db) for both of the vintage systems and am 100% happy.
Crown micro-tech 1000 - 250wpc@8ohms
Carver PM600- 200wpc@8ohms
Crown XTI 4002 - 650wpc@8ohms
Carver TFM24 - 225wpc@8ohms
Crown XLS 2502 - 440wpc@ohms.
McIntosh 4100 receiver. I use it with 4 ohm speakers(AR3) where it pushes out at least 100 watts .
The Mac has since been replaced. I now split duty with this(about 22-25 watts)
And this, about 35 watts
15WPC JLH 1969 Hood integrated
45WPC Oldchen KT88-K3 integrated
80WPC Tascam PA-R100 AVR
100WPC Quad 405 copy power amp
140WPC darTZeel NHB-108B copy power amp
I won't bother listing the various little S.M.S.L class d amps. Only the AD18 see's any kind of regular use.
Let's see, they are: 4, 17, 18, 20, 30, 50, 125, 140, 180
My system used to be in a much larger room, 600sf. Now I've downsized to 230sf. And I sit closer, only 6' now. Between this and listening at a bit lower volumes, I find that I can run on much less power.
Questions on power. I had a CJ MV75 75 Watts per channel. I had a dynaco st-70 35 Watts per channel. Now I have a Single ended ultralinear amp (diy with modifications) using 1 6550 per channel. I get around 9 watts measured using an 8 ohm dummy load. I can’t even max out the amp when my speakers are connected.
I understand the idea that higher power amps have more “headroom” for transients. But my 9watt amp appears to be more than enough. My speakers are very effiectient 98db
Help me understand why / how lower power amps can sound better than higher power amps. I have heard this with low power 300b amps as well.
