Just to set the record straight, this discussion got started when I stated:
Which is true, but it prompted this reply:
Which led to me asking about the amps being less linear at low power and him providing an example, which resulted in this reply, which still stands:
As I stated so long ago, "as long as the distortion is always below the point of audibility, it does not matter if it is higher at one output level than another. It is only when the amount of distortion becomes audible that there is a problem for humans listening to it."
Which we have reached yet again in the postings of others.
What I was disputing was not whether or not amplifiers distort more at their lowest power levels than at half rated power; I was disputing whether that mattered. And it does not, as long as the distortion is inaudible.
He has given no reason to believe that having more powered than needed is a problem, which is the start of this lengthy discussion.
Ironically,
he posted examples in which the high powered amplifier had less distortion below one watt than the low powered amplifier, and yet
he seems to imagine that the lower powered amplifier has less distortion at low power levels than the high powered amplifier.
The simple fact is, one cannot determine the distortion below one watt based solely on maximum output power capability. That is a nonsensical idea.
As I stated originally, having more power capability than one needs is not a problem.
