Actually, that's the point of ALL high bias AB amps that remain class A for the first 5-10% of their rated output. Two examples are the Parasound JC-1+ and the Pass Labs X260.8. Both John Curl and Nelson Pass understand the concept.
On that we agree. I am firmly convinced of the value of stiff power supplies with providing a sense of "authority" and dynamic power. Yours have 35 joules each or about that of my preamp.
When folks like to post how extremely powerful their amps are I'm reminded of this quip from Paul Klipsch.
"Bragging about input power is like bragging about how much fuel your car can burn"
You asked I provided, if you don't agree with Mr Holt then take it up with him in the afterlife.
For further proof a bit more updated.
Fig.6 McIntosh MC462 (8 ohm output), both channels driven, distortion (%) vs 1kHz continuous output power into 8 ohms.
AS I stated, solid state amps "are more linear" and more than ten fold, you know exponentially as they approach rated output.
Here's another Mac, this time a tube amp, notice the general trend upward as the output increased, the exact opposite from the above SS amp. This is what the late great J Gordon Holt found to be true about the Dynaco and why he praised it, most likely partnered it with sensitive speakers. Later reversing some of his praise, was this due to driving more difficult loads pushing the amp into distortion? Hell if I know, but it would make sense eh?
Fig.6 McIntosh MC275, 4 ohm output tap, distortion (%) vs 1kHz continuous output power into (from bottom to top): 16, 8, 4, 2 ohms.
If you look at the numbers on the scale on the left of each graph, the solid state amplifier is more linear at low power than the tube amplifier, for the entire range shown. The fact that the distortion goes down at higher power levels means it is vastly more linear at those higher levels. So, that solid state amplifier, as far as can be told from the data you have given, is just better at all power levels. It is more linear at low power and much more linear at high power. It has less distortion at all power levels that are shown in the graphs (from 1/10 of a watt on up).
So, the evidence you have provided is in favor of high powered solid state, not what you originally seemed to be asserting. Being higher power does not cause it to have more distortion at 1/10 of a watt; it has less distortion at 1/10 watt.
Nope. You can easily find some that exceed the joules per watt ratio of yours.I think we can both agree that no class AB amps have such disproportionately large power supplies.
My statement was "solid state amplifiers are more linear as they approach rated output" you asked for data proving as such, you even quoted that exact statement and asked for proof, you have your proof. And now that you have your proof you want to sidestep out if it lol. If you like I can copy and paste my statement here if you want to dispute such.
As for how much distortion at either end, that is a $9,000 amplifier lol. If I felt the need, which I don't, I could easily pull up graphs where the solid state amp didn't look as good at flea wattage output.
Just so there's no confusion on just what you asked for.
SS amps typically become more linear the closer they get to rated power, the opposite of tube amps, added to that it's not great to have your speakers hit their max peak output at just a crack of the volume output, meaning 1 on a scale of 11 lol.
So yes, you can have "too much" power, and why the SET guys run flea watt amps.
DIY F5-35 joules/25 watts = 1.4
Audio Research REF75SE-520 joules/150 watts = 3.4
Parasound JC-1+-1240 joules/400 watts = 3.1
Atma Sphere MA-1-600 joules/140 watts = 4.3
My amp runs both triode and tetrode. In triode mine comes close:
VTL MB-450-250 joules/200 watts=1.25
Mea culpa. They are 30 watt DIY F5s. That reduces the ratio to 1.2.I don't have 25 watt F5's.
Did the math. 120,000 uF running 24V rails. Similarly, Nelson recommends between 23 and 25V.And where did you get 35 joules for an F5 power supply?
I'm thinking you don't understand the formula: J=C*V*V/2It's more like a minimum of 200 for a stereo power supply, and the power supply in mine will belt out a hell of a lot more than that.
Sure it does.Yes, that is what I asked regarding this post:
The point being, the information you posted does not support the idea that lower powered amplifiers have less distortion at low power levels than high powered amplifiers.
Having more power than needed is not a problem, which your evidence proves.
Having high distortion at low power would be undesirable, but having a high powered amp does not mean that one must have high distortion at low power.
Not necessarily. I purchased an AR Integrated amp to drive Advents when I was 15. At high power, it sounded great. Resolution, however, fell apart at low levels. This was a valuable lesson that I had never fathomed. Avoid designs that are largely class B!Sure it does.
For a power supply with 120,000 uF to have 200 joules, the rail voltage would need to be 58V.
Sorry, clearly you don't understand the formula.No, no, no, Grasshopper! That's not how this works at all!
The measure of energy storage has nothing to do with an amp's idle current.First of all, the power supply needs to deliver a constant 90 watts just to idle one channel.
Output devices dissipate current. Joules is a measure of power supply energy storage.If the amp is idling 1.4 amp at 32V per output device, it's obviously dissipating way more than 35 joules.
Show me where I said "high" distortion lol?Not necessarily. I purchased an AR Integrated amp to drive Advents when I was 15. At high power, it sounded great. Resolution, however, fell apart at low levels. This was a valuable lesson that I had never fathomed. Avoid designs that are largely class B!
Nine years later, I purchased a Threshold Stasis 3 amp which proved to be the antithesis of the Acoustic Research. It resolved down to a whisper.
I would hardly characterize this Pass Lab amp as exhibiting "high distortion at low power"
Matters not to me whether or not you accept the definition.
I use a spreadsheet, but here's a web resource:
https://www.electronics2000.co.uk/calc/capacitor-charge-calculator.php
Sure. In post #152, you quoted Pyrro's comment:Show me where I said "high" distortion lol?
