Can anyone tell me if this treatment will help the tuning flywheel do its thing again?
Not likely, I'd opine. The treatments here are focused on electrical properties.
That being said, there are ball bearing races on at least the pulley end of most tuning caps, and the races can sometimes benefit from refreshed lubricant. I use a small drop of light-ish penetrating oil like 3-in-1, but your judgement is probably better than mine.
A key question is whether the excessive friction is from the tuning cap or elsewhere, such as the tuning knob shaft. I don't know how to express this idea well, but one thing that can be helpful in figuring out what's resisting motion is to observe how the tuning cord tautens or slackens at various places as the tuning knob is turned.
Cheers,
chazix
https://www.princessauto.com/en/det...rength-electrical-contact-cleaner/A-p8180507e
These reviews say it might not be safe for plastic?
Not to be picky, just try to learn new stuffs here.
attempted to clean my tuner with deoxit. it was very scratchy when tuning and the deoxit cleared that up wonderfully. However, it would no longer tune in any station. Then I read this thread and oops, now what? Bought the non residue cleaner and it all came back better then before. About to use the fader lube then new lamps and close her up. Just as a side note, I have a coax antenna and when it was hooked up to the unbalanced connection it gave lousy reception. Was ready to take it in, but I tried the balanced side and everything works great now. Crazy thing.
Bad cable or loose rf connector.I have one of those highly respected oval antennas that were all the rage a few years back, cost me 30 bucks. I finally (3 years later) got around to hooking it up, and the reception is really good, but I have noise. I can adjust where the noise is gone, but signal strength plummets.
To further muddy the waters, literally moving the coaxial cable I have connecting it makes a HUGE difference. WTF is that??? It doesn't seem to like to be looped, or anything other than straight.
I suspect no shielding??
Well, I tried 2 different cables, so it may very well be that little adaptor, which is indeed dirty and old. We'll try a new one. Thank you!Bad cable or loose rf connector.
