Ah. Same as my 240. Just make sure to observe correct polarity.
my amp doesn't have those white and black connections for the loudspeakers. its just some screws.See here:
Preamp L and R RCA cables plug into the Inputs hacks. Speakers connect to the Loudspeakers jacks. Make sure to connect them so that the same leg is on black or white for each speaker.
Preamp out goes to amp via RCA cables. Turntable to either Phono 1 or 2, tuner to Tuner or Aux 1 or 2.
Yes, there are different size lugs for different gauge wire.so if I had multiple sets of speakers that would be useful but since I only have 1, then connecting to the power amp will do. but with there only being screws to attach to, should I even attempt it or just buy the spade lugs? do those lugs have to be matched with the gauge of speaker wire I have? I would like to try it now without the lugs but if you guys think I can potentially short something out then I will just leave it alone for now
I already have 2, 1 of them has 2 outlets that are labeled always on, 4 that are " switched" and then 1 says master. another one I have is all the same outlets and 1 switch to turn it on off, this is the one they are plugged into.Another tip: Get a good four or six outlet surge protector with a power switch, keep all of the components turned on, and use that to turn the whole system on or off. I stress good, not a cheap local hardware store power strip.
If you decide to put the bare wires on and snap a pic for Lucky, when you put the amp back in place make sure those wires don't twist or pull.
When they twist they can pull strands loose from the screw.
That's a good way to ruin your amp.
You may not be as lucky.
Use spades.so if I had multiple sets of speakers that would be useful but since I only have 1, then connecting to the power amp will do. but with there only being screws to attach to, should I even attempt it or just buy the spade lugs? do those lugs have to be matched with the gauge of speaker wire I have? I would like to try it now without the lugs but if you guys think I can potentially short something out then I will just leave it alone for now
Thank you, are crimpers necessary for this connection? I went on Amazon and unless I’m not seeing the correct ones, seems like they have to be crimped. They are the ones lucky posted a picture ofUse spades.
Banana clips are not an option.
Spades come in a variety of spade widths and sleeve diameters. Match sleeve diameter with speaker wire gauge; standard sleeve diameters are 10-12 gauge, 14-16 gauge, etc. Make sure spade width is as small as possible but still fits the screw.
Get something like these and you are golden. BTW, I have been connecting bare wire to amps and receivers for almost 40 years.
Maybe you can post a picture of your connections before you power everything up.
What I see in that picture is that your wire gauge is too thick to use this way. Get the spades, or use thinner wire and tin the ends, then bend to fit.
How long is your run? For short runs, 16, or even 18 is ok.
If you use bare wire, it should be completely under the bolt head when they are tightened. You don't have to crank down on the bolt. You want the wire to be tight under the heads, but not squished out.
