Are you able to take pictures of your entire setup, interconnects and all, from the back?
Kester 44, .8 mmmy run is only about 10-13ft. I am going to end up switching to 16 because the 14 is even a bit of a pain to get into the back of my pioneer sx850. thanks for the tip on the wire not showing under the bolt head. I will switch that out soon to 16. is it necessary to tin the wires? I have no problem doing that, I just have to order some solder. Any tips on what solder to use?
Hey guys, bit of a bad update here. Not sure what the hell happened between tonight and Friday night but this 3300 won't turn on. Came home from the tech on Friday afternoon and hooked everything up, tried it out and no problems at all. My tech even replaced the light that was out on the unit for free. Watched him do everything too which is great because he showed me on all his gear that everything was looking perfect.
Before I took it in on Friday to the tech, the 3300 was working except for the light. I could see the meters on my 250 moving as I was adjusting the volume though. I had no sound but that was because I had the speakers hooked up to the 3300 instead of the 250, like a dum dum I know. But after I tested everything out once I got home from the tech on Friday, nothing has changed. I turned the power strip off and off it stayed until I came home from the firehouse this morning.
No moving meters on the 250 as my tt is playing either or when I adjust the volume. checked the fuse and it didn't look blown. plugged the 3300 into a different power strip and directly into an outlet but nothing still.
any thoughts guys before I end up taking it back to my tech on Friday? Really was a bummer tonight, I had Aerosmiths live Bootleg record from 77' 78' tour ready to be blasted. I do have 2 new sets of rca cables coming from amazon today so I can connect the 120 tuner to the 3300 and see if that works on the tuner setting. im not thinking it will but I guess there's a chance the light could be out again and the 2 phono stages are blown?
thanks, I did edit my last post on the 2nd page with pictures of the setup for you.
lol, I was thinking its no bueno myself. I hope it's nothing I did. the speakers are connected to the 250. I tried the 2 tape monitor buttons as well. would my dicey speaker wire affected the 3300 even though its connected the amp? the amp comes on and I hear the relay switch a few seconds after.That's no bueno.
Are the speakers connected to the 250? Your connections looked a little dicey. Sure hope you didn't short them.
Any chance you have the tape monitor switched on?
BTW, there is only one phono stage.
Yes, two phono inputs.
No, speaker connections will not affect the 3300. I did not realize you had already identified the 3300 as the failure point.
So its power indicator isn’t coming on?
I did, it looked intact.Did you check fuse on 3300?
Do you have a multimeter?
Use it to see if 3300 is getting power. You can just probe one of its unswitched outlets.
And use it to confirm fuse is good.
Or just plug a lamp in it to see if it lights up.
I will try both of these things first thing in the morning. Would having the 3300 on and then turning the power strip off do damage? I’m pretty sure I turned the unit off and then the power strip though
It eliminates the aftermarket plug as a problem.
It also shows that the on/off switch of your power strip is not working, if indeed you are getting voltage from the 3300 when the power strip is turned off.
Time to get the unit back to your tech.
