drummergrl
Well-Known Member
What kind of switch can be used to set up 2 preamps into one amp to compare back and forth?
Simple. I wanted to be sure. Thanks.Back of the box you will see one set rcas marked out, 3 sets marked input. Connect one pre to one of the 3, and one to another of the three. Connect out to the power amp.
This is the same as the Radio Shack input selector you're saying?Niles Audio makes something called an 'amplifier selector switch,' but is a basic A/B switch as above... I used it for years to "tell" my amp to listen to my 2-channel, analog pre amp, or to be the front channels for a 5.1 home theater system... great piece of equipment.
So when you connect the preamp to an amp in a normal fashion you use the preamp out. It is alright to use the inputs in a switch selector to connect 2 preamps?
