IMF CM 3 X-over
Compact Monitor X-overView attachment 599164
This is the schematic that I got from Falcon Acoustics, Jerry says it's the same thing
IMF CM 3 X-over
Have you recapped the crossover?Had a sweep done on my CM3'S, though the old IMF website says that these are supposed to dig down to 29Hz the start dropping off abruptly at just above 100Hz. I can see the factory fudging the numbers a bit but they drop off about 20db's, not even close.
I had the sweep done by Meniscus Audio, they said that they didn't think that the port was doing anything, or that the surrounds had dried out. They also mentioned playing around with the foam in the port, however that would definitely be a last resort as I prefer to keep them as original as possible. Any suggestions on what might be going on to have lost so much of the low end? Seems they use these same woofers in many different systems, anyone experience this problem with these woofers?
Thanks!
If you have the speakers back, I would play around with some software like Function Generator - I run this in my iPad and then use Sound Tools on my phone to watch the decibel response.
After seeing where things stand, start experimenting. Are there any holes in the cabinet? Do any of the drivers or the rear terminal plug need new gaskets or sealing caulk?
also check the speakers one at a time, if there was a cabinet or driver flaw from age or part failure, I would assume unequal problems. If both speakers measure identically, I would start to look at the new parts and how they are installed.
If anyone were to look in the antique section of a certain public sales site in the Portland region they would find a set of imf the studio for sale. With moncor mids and updated crossovers per falcon acoustics. They were mine, I want them back but just can’t get to them.
That price is damn near a steal too... If I didn't already have the 80 and 50MKII I'd check into shipping them up to me. Sorry for your loss!If anyone were to look in the antique section of a certain public sales site in the Portland region they would find a set of imf the studio for sale. With moncor mids and updated crossovers per falcon acoustics. They were mine, I want them back but just can’t get to them.
yeah the apps I referred to are on Apple's store
if those exact ones aren't on Google there will be others that can do the same things, and testing both speakers might help narrow down where you're having trouble. I also would not want to pull out the foam!
photos would also help us get a better idea of what you're seeing
@Yvan_donald were you referring to the cardboard tube that encloses the midrange on the TLS-50's? I'm not sure if @JB1962 's CM3's have the same structure, but it is worth investigating as well
My first thought is still about gaskets, to make sure the driver is securely sealed to the baffle and the sound waves are traveling through the transmission line as designed.
but I’m also curious about what’s happening with the bare wires and that silver structure ?
Hi, this is for JB1962, checking in my inventory I have found an 8/30 (1) woofer,Yvan.
