Hi Dave,
I finally got around to pulling the SA100 apart and installing the ESBII circuit. Although I could use some diagnostic help.
The screen supply is only giving me 150vdc.
For the MOSFET: I have 400+vdc on the Drain (2 red), but I am only getting 150vdc on the Gate(1 green) and the Source (3 black).
I have solid B+ of 400-445vdc (I have it plugged into my variac to check voltages) feeding the circuit, then the 91k resistor to the Gate with a 12v Zener then connecting that to the Source/Screen.
Also, I sanded a few areas and installed ground lugs and then connected all the grounds to new buss wire. Signal on one and the PSU on another meeting up at the ground on the input jack.
Do you see anything obvious that I am missing?
Excuse the messy lead dress. It was such a bear taking everything out. It is such a lovable rats nest.
Thanks for any help you can offer.
-Ben
-Ben
