if you are going for matching, you also need to pay attention to rank. e.g. O vs R vs YI should keep them matched
145 and 153 are flameproof fusible 1/4 watt..
151 is a 1/4 watt carbon film.
Mount it well above the board.Also R125 was missing another flame proof , all I have are metal film 1% .
They are probably " open "..Yep, Also the two Fuses FR101 and 103 measure 80k in circuit, going to lift a leg and measure again.
Are the " metal plate" emitter resistors still serviceable ?
If you use Sanken outputs you will need the Sanken MT-200 size mica.. The OEM Toshiba MT-200 insulators are just a tad bit to small.
Yep , Open. What do you sights for there?
I have a couple different value of this Green type fuses.
OEM was Fusible 1/4 watt.Looks like they used a 1/2 watt for R129 , replacing with a 1/4 watt
They are 10Ω@160ma -- 10Ω 1/4 watt flameproof
They are listed on the schematic legend LH side..
