NH-MAN
Addicted Member
Funny, how there aren't a hundred threads on my cables (or other product) sound worse after they broke in; always better.
Why wait all this time burning them in, just make and adapter and run them inline on a hair dryer or something for 30 seconds and be done with it.
If a cable was available already burnt in from the manufacturer as an option, would you pay a $100 premium on a $1,200 set of cables? Why waste time on an inferior product for100 hrs?
There is no such thing. A cable isn't a resistor, tube, or other electronic element. Those may (or may not) require burn-in. In fact, your interconnects will be at their peak, ONLY the first time you use them after you took them out of the box new. Over the course of time, the cable, connectors, and internal connections deteriorate. The cables will increase their resistance and thus DECREASING their throughput as well as the accuracy of the throughput. It is very similar than a battery cable on your car. Over the course of years, the cables deteriorate to the point that you have to replace them. You might go to the car parts store or to a mechanic and get a new cable or have it installed, but you will NOT be buying a used cable with high resistance, but a new cable in optimal condition.
