A few comments about my build:
1) I was not able to source a 300Ω 5W pot for the DC balance control. I was going to use a 250Ω pot with a 25Ω resistor on either side to maintain the same overall resistance but knowing it would lessen slightly the range of adjustment. Dave said it was fine to substitute the 250Ω and there was no need to add the 25Ω resistors - so that's what I did. The stock W-5M already has this pot, so if you're modifying an existing chassis then you already have the right part.
2) The cap can that you see on my chassis is a quad 40-20-20-20. I was initially planning to use the individual sections as the last filter cap in the series filter strings for each voltage take off. However, once I worked out my grounding I realized that the shared common would prevent me from grounding each filter network using separate star clusters. The chassis was already drilled and the can mounted, so, I ended up paralleling all 4 sections and using it for the final 100uf filter on the -40 supply. Obviously a 100uf @ 63v would suffice for that application and easily mount inside the chassis and have cost a lot less money. Lesson learned. And yes, the cap can body is at -40 referenced to ground, but I have it painted and might consider some clear heatshrink on it as well if it doesn't look too bad. The cap is after the dropping resistor in the circuit and I calculate the maximum current draw at a dead short is only 22ma. Nobody wants to feel that tingle when you touch an operating amp, but it's certainly not a health hazard.
3) The solid-state rectifiers I used are ultra-fast, soft recovery HEXFREDs. Vishay VS-HFA08PB120. I know that is a subject of much discussion, but I have read that they are "quieter" and can help in providing cleaner power to the amp. More importantly, I was trying to minimize voltage drop since my PT has a lower HV winding that the stock W-5M and I want to get as close as possible to the design voltage.
4) I used Jantzen Superior Z-caps for the coupling caps. Again, much discussion about whether caps can actually color or influence the sound. I don't have enough experience to have an opinion one way or the other, but these sound like a high quality part and I found someone selling them cheap on eBay so in they went.
5) When comparing Dave's schematic with the stock W-5M schematic, you will notice that the output transformer primary leads are swapped. I noticed that and asked Dave whether it made any difference. He reminded me that since his design has one less gain stage, the swap is necessary to keep the phasing correct for the negative feedback signal. In his words - "You better believe the lead color matters! If you reverse them from that shown, the negative feedback becomes positive feedback, turning the power amplifier into a power oscillator!" LOL - I'm glad he is patient with me because I know I have asked a lot of questions that the answers are obvious to the more experienced.
6) I'm wondering if I should have drilled some ventilation holes around the damper and power tubes. The chassis bottom cover is perforated, but without holes in the top of the chassis to allow some sort of convection flow, I worry about high temps inside the chassis and around the hotter tubes.
7) I asked Dave whether this design could benefit from a form of his EFB(tm) circuit. His response - "Once the unit is built and you test it, measure the B+ voltage when the amplifier is driven from quiescent, to full power output. I doubt that it will change very much, meaning that EFB will do little if any good in this case. Of course, testing will prove that out one way or another, but I'm comfortable that will be the result."
8) Since I am building a pair of these for stereo use, I wondered if it was important to keep the phasing of all the A/C power windings the same for each amp to ensure there was no weird phase interaction or cancellations if the two amps were somehow out of phase with each other. Dave pointed out that after rectification, any A/C pulses present are at 120Hz and therefore in phase even if the power cord is reversed in the socket. I did note however that the -40 is derived from 1/2 wave rectification and potentially could have pulses 180 off from the other amp. I feel sure I'm nit-picking, but to be sure each will be wired exactly the same in all aspects, I used a 9v battery and a very sensitive mechanical meter and pulsed power to the PT primaries and determined a "positive" lead for each winding of the PT to establish it's phasing. This will allow me to wire each amp in an identical manner, and that, in conjunction with a polarized 2-prong power cord will ensure both amps are operating the same in all respects.
