Dswankey
Lunatic Member
Zack is correct - I'm building a pair, but only did one so I could make sure I liked it before building the other. It is sounding very good indeed!
Nice!!!!!!
I'm pretty sure the wood on your new cases is African Padauk. Beautiful material.After a side discussion with Dave on these voltage differences, I plan to remove the bucking circuit and assess where that shifts things. As long as the heaters stay under 6.615vac, I will likely do that and then also modify the value of the 6.8K dropping resistor to the driver/inverter stage to get that closer to the 425vdc design. I'll continue to provide updates, but I'm already considering this project a success and plan to start on the second amp soon. I appreciate all the input and most certainly appreciate Dave for the excellent design and support!
That sure looks very similar in grain and coloring. I'm pretty sure mine is only oiled with no stain as I see no differences on the insides.I'm pretty sure the wood on your new cases is African Padauk. Beautiful material.
Padauk like many woods will darken with age. Its still very attractive tho.That sure looks very similar in grain and coloring. I'm pretty sure mine is only oiled with no stain as I see no differences on the insides.
FWIW- IME, it was the 16309 output transformer, used in the early Heath W5 amps, that was more fragile. The 16458 was introduced to replace the 16309- and seemed to be more rugged...
I won an auction for an HP Agilent 54501A this morning for $9.99. It fails self test for a NVRAM issue. I researched and this is a very common issue with this model series due to a Dallas NVRAM module failing after it's internal lithium battery dies. The part is still available (Mouser $24) and the repair involves desoldering a 28 pin DIP and replacing - socketing it, of course, like HP should have done. I'm pretty excited about the prospect of getting a pretty nice scope for cheap. The biggest expense is the $40 shipping, but should be all in for $75.I bought a GK Intek 620FG for $60, obviously some lab dispensing their old instruments. It works fine. I don't see any that cheap right now on eBay but the GK Inteks are usually portable and will serve your purposes fine. The Picoscope 2024 is about $120 without accessories and works very well, convenient to have screen captures and measurement features. It's signal generator only goes up to 100kHz so you'll need a better SG if you want to check for HF oscillations.
No, not yet. I'm still tweaking the voltages a bit and waiting on an oscilloscope so I can do some basic testing. Gadget73 planted the idea of mirror-imaging the other amp, which I really like that idea. Unfortunately I had already marked the other chassis and center-punched the holes. I think I'm still going to do it, but will have to fill all those divots.Good idea, have you had a chance to start on the second amp?
