The copper braid (uninsulated) is a shield. It catches EMI and drains it back to the TT's ground. The braid shields the signal wires.
The shield is not connected to the RCA plug's ground.
The two insulated conductors in the cable are for the cartridge's signal (R) and ground (W).
The fifth terminal is Ground. You should run a separate wire (green) out from that terminal to the input of your phono stage.
It can be argued that the green wire is redundant...and it probably is. That seems to depend on the turntable. On my turntable(s), the ground wire has continuity with the center spindle. It seems to drain static charges that develop on the surface of the spinning vinyl. Without the green wire...some people get hum, I hear static during playback.
