ISO a Canton CT-120 woofer
nimM
AK Subscriber
Wondering if anyone knows where I can purchase a 12" OEM woofer for Canton CT-120 speakers. I already tried contacting Canton directly but they said they didn't carry them anymore.
The correct woofer should be part number 3238.
Keep your eyes on ebay.de
There are none showing at the moment.
Cheers,
James
Thanks for this info! Do you know if Canton ever published a parts schedule that might recommend suitable replacement part #'s?
None that I know of.
My first thought was to suggest something from an Ergo, but when I looked they pretty much exclusively use 2x 10" and smaller woofers there.
One thing that comes to mind, and it may be a longshot, is to go older and use a 2243, 2740 or 4561 12" from a CT-2000. Those numbers go from oldest to newest of the 3 different 12" woofers they used in that speaker.
Cheers,
James
Any canton parts are hard to find. Let alone for 100s and 120s. I just found a replacement set of high-mid drivers for my CT-100s after they got lost in the post. Was extremely hard but I found a gentleman in the Czech republic via the canton facebook group. Are they missing or damaged?
I wonder if the 12" driver from the Plus C passive subwoofer would be the same part number? I have one sort of, gave it to my oldest son so not here for me to check the part number.
Most likely not as it has a paper cone and from the pic you posted those look to be polypropylene?
Its not. The plus C is a dual voice coil driver. Significantly smaller magnet and voice coil.
