ISO Marantz 2265 selector switch?
Jblitz99
hello, Im needing a selector switch for my 2265. Part # SR10060150. Fedex busted mine off during shipping, not having any luck tracking one down. Any help is appriciated.
Best bet is to just change the shaft(not unsolder the bizillion wires) once you get a donor switch.
New faceplates are also available should you need one if yours got bent or scratched.
Bob
Bob
Might be the route I go if I can find one. Ive carved a groove into the broken shaft with a razor blade, I can switch it but I want it fixed. Also when I switch it dosent click into position, im thinking something inside might have taken some damage also. Found a couple metal ball bearings loose inside when i took the bottom off. Did they come from the switch?
There are a couple of small b b's (balls) that serve as the detents in the switch so yes they probably fell out but I never take that section of the switch apart when I swap out the shaft assembly.
It's not for the faint of heart but if you take your time and have steady hands it beats the alternative by a mile.
Bob
Hi
Anyone got any sources for a new compatible replacement of protection relay for Marantz 2265?
Thanks
Hi
Thanks
I would ask in the Marantz forum. That's how I found the relays I needed for my Marantz gear. Depending on the Marantz model you may have to pop the plastic cover off the new relay and swap a couple wires, but some are just drop in.
