GD70
Lunatic Member
I have foam left over from when I restored my Time Windows. It's air filter foam but also sold as grill foam. I'll post a closeup pic when I can and see if you gents think this will work.Yes Earl is right, the foam is attached to a thin piece of felt which is glued to the back cap of the driver and doesn't touch the diaphragm. The foam is supposed to be open cell of which I had difficulty finding so I made my own from a sponge like the tile guys use for cleaning grout. I cut a half inch of the sponge off with a sharp knife and then cut a circle pattern and glued it to the sponge. Then glued that to the back cap.
I know this sounds a bit backwoodsy but it did the trick and I couldn't hear any difference. I heard where the original foam may still be available from JBL so if you are doing this, and I think you probably should at some point, then I would definitely try to source the OEM stuff.
Using a very sharp kitchen knife.. (wife does NOT know!)
I used felt from a turntable mat I wasn't going to ever use, but should be able to find this stuff easily..
Felt/foam glues to inside of the back cap of the driver, felt to the back...
Be cautious as can be about both the screws and the crimp on forks as those are ferrous and will want to jump right onto that fragile diaphragm! Hence why I replaced both diaphragms with new ones (Radian 16 ohm). I only dinged one but I decided to change both diaphragms out so as to be a matched pair.. I got lucky that these Radians sound great, perhaps even better than the OEM and go for only $80 instead of $160 ish on eBay..
Glenn
