johnjhazel
PhxJohn
I just checked both of these.
Bonded. The HE is a 2x7 bonded elliptical. The 75 is a bonded 3x7.
The ellipticals are the typical flatted conicals; 2 flat facets ground on front and back of the conical.
They have shiny metal “Stubbs” that synthetic black tips are glued to. Pressed into the cantilever foot.
When I look at the ellipticals, I look at the width of the flats ground on the front and back of the conical black (color) diamond tips. A 4x7 has barely perceptible flats. A 3x7 is easily seen. A 2x7 is relatively very broad flats. The Kyowa N95HE has the very broad flats. Not a true HE, but at least better than a typical 3x7.
The construction of the 95 is interesting. I’ve never seen it before. The end of the cantilever is pressed into a “V” shape inside the housing. There is a magnet cylinder glued to that cantilever “V” shape; the tie wire is attached to that “V” and is soldered to the brass housing’s end.
So the tie wire is counterfeit. There is no bearing plate as is used on a real Shure stylus. A Shure stylus has a brass plate that forms the fulcrum of the cantilever movement. The suspension is strictly for damping and spring, aft of the center of rotation (fulcrum) of the cantilever. So even the Kyowa uses the suspension block as a fulcrum, spring, and damper; just like the Pfanstiehls and EVGs. That means it has center of rotation of the cantilever in the middle of the suspension block; damped fore and aft of the rotation. Just like Pfanstiehls and EVGs.
Great info Wolfie62. You have the most informative and interesting posts. I had looked at the tie wires on a few Kyowa back whenever the 'Kyowa for Shure' thread was created. I saw where the tie wire was soldered to the cantilever housing but I could not see well enough to see where it went exactly. I have never been of the opinion that a needle with a tie wire is better than one without. If the tie wire is part of a bonafide suspension design such as those created by Shure, Pickering, Stanton, and any correct aftermarket duplicates, then there are benefits such as reducing fore and aft movement, defining a precise pivot point, and exerting a downward force on the cantilever. To add a tie wire as window dressing serves no useful purpose and can introduce resonance. I think it was Peter E Pritchard of GE, ADC, and Sonus fame who was not a fan of tie wires due to the resonance potential. Notice I said 'potential'. I am sure that the Pickering, Shure, and Stanton tie wire designs were excellent.
