JVC QL-7 Turntable; unstable speed
I use vintage test records as all the new ones I've tried are rather poor. Also, pressings matter as my best and worst are the same Denon test record. Really, most important part is to get to know the record by plotting multiple 'tables that are known to be running right.
Yeah, I'd say the results are inconclusive without a second reference point.
My first test record was wildly off center. Made it basically useless.
I've run tests with my second record enough to know that if my app is averaging under 0.06% or so the table is doing good. Either that or every table I've worked on is uniformly bad. :rflmao:
Go for it. Most time consuming part is editing the file. Polar plot is a python script.
Will most likely do so tomorrow, with my trusty JVC QL-A2, and then with an idler drive Garrard for fun. Thank you very much for sharing your expertise with me - without the help of this forum I likely would've given up on this turntable already.
Could recording the clips in mono have caused any problem?
I use vintage ones too. I have probably 6 or 7 here and a few at Dad's place. The key is as JP said, getting used to the record. I know that sounds weird but through each W&F track on all the test records, they vary a little, and you can either compound or cancel your errors/readings. Add that to the slight off centre of practically all records and one has to make several tests rotating the record on the platter IME to get meaningful results.
On closer inspection, there are several stress marks / cracks on the underside of the platter near the part that meets the spindle. Is this damage, or something left over from manufacturing?
I don't think its from the factory and maybe causing the clicking sound?
With the platter on it's actually a very very quiet buzzing sound once per revolution. If I knew how to I'd change the title of the thread [Edit: I figured out how to!]. Doesn't sound like a grinding even... More like an electrical sound, a coil charging or discharging maybe. When I get a stethoscope I'll make a recording of it. I need to do the motor tests which @EngineerNate suggested next time I have it disassembled.
There are a handful of these 'cracks' around the spindle hole. The thing is, this platter is so thick and heavy that it would be difficult to damage that way.... And it doesn't show any signs of being bent - spins true and flat, as far as my eye can tell. The inside of the spindle hole has no apparent cracks.
In the meantime I took Scotch Brite to the spindle hole as advised by @EngineerNate, and also scrubbed the rim of the platter and the inside of the plastic housing around it just in case something was rubbing - made no apparent difference.
I have a bunch of things to check now - transistors, waveforms, voltages, motor... I'd been hoping to narrow it down, but I just have to roll up my sleeves and get the data - then the picture will be clearer :)
Thanks to all who have advised!
@JP After playing that test LP on several turntables I am now absolutely convinced that it is useless, so no point in sending you those clips.
However, digging around in my collection I did manage to come up with some other test tones which should be more reliable:
One set is from a Shure test record (1kHz only)
The others are from a Folkways educational record "The Science of Sound" which has recordings of a tone generator.
You can access both sets of audio clips at the following link:
https://www.dropbox.com/sh/3hwys8o9i0cq7mc/AADimowDy3KXbQ1_qRFXVsQ1a?dl=0
Hopefully this will give a clearer picture the w&f.
Thanks again for all your help!
P.S: I am now an AK subscriber! I wanted to support this website which has been such a great resource over the years. I've only ever started a few threads, but have read probably thousands.
Been playing around with a program called wfgui downloadable here: http://www.ant-audio.co.uk/index.php?cat=post&qry=library
It claims to be a software w&f meter.
By recording the Shure disc's 1kHz tone in audacity, changing speed to equal 3150 Hz, and looping the tone... The program is telling me I have a w&f of ~0.06% RMS or ~0.10% peak.
If accurate, that's somewhat decent, isn't it? That is of course just from a single recording; not compensating for the eccentricities of the disc, which I don't know how to do.
Will be interesting to see what @JP 's plots show.
Been following this on VE a new program for W&F.
That app gives me the following readings:
44.73 rpm; WOW +/- 0.04%
33.14 rpm; WOW +/- 0.05%
So this means that the table is running slow too? :(
Confusing, because my speed discs wobble, but they don't drift...
I wonder how accurate it is... My JVC QL-A2 tests very similarly for speed...
(This app says wow is actually worse on the QL-A2 than the QL-7)
Is this with digitally altering the file to have the right frequency or did you find a 3150hz test LP?
Quoting myself from earlier: "By recording the Shure disc's 1kHz tone in audacity, changing speed to equal 3150 Hz, and looping the tone... The program is telling me I have a w&f of ~0.06% RMS or ~0.10% peak."
It's a 1kHz tone sped up to 3150 Hz.
While you're here.. Do you know much about the neon bulbs for turntable strobes? The SM doesn't seem to give a part number or any specs, but the schematic seems to indicate that it runs on 160V DC... If I'm reading it correctly. What other parameters would I need in order to replace it? The old bulb flickers consistently.
Regarding the measurements from the phone app, I'd expect +-1% accuracy on the gyro/accelerometers in the phone with that app. So don't worry too much about the absolute speed measurement from that one.
On neon lights, I'd look into the circuitry driving the neon. I'll take a look at the schematic. I would expect the bulb itself to either work or not.
I haven't read a lot on neon failure modes. Did you replace the caps in the strobe circuit? Bad caps there would cause issues as well.
I'm know I'm getting a bit ahead of myself here, but I filled the bottom of the plinth with plasticine today. Even if I have to buy another QL-7 I'll probably use this plinth and arm, so not as crazy as it might sound.
For reference, in case anyone else wants to do the same to their QL-7 in the future: the maximum amount of plasticine that can fit in the plinth is ~3.5 lbs.
