Just wanted to drop some useful information here for future QL-7 owners:
The arm lifter mechanism as shown in the
QL-A7 (automatic version) service manual
is different, and easy to service. The QL-7 manual makes no mention of how to change the silicon oil, and it took me quite a while to figure out how to do it! In the QL-A7 the whole assembly is removable, but in the QL-7 the shape of the tonearm base makes that impossible.
When I unscrewed the lifter arm and removed the screw, it exposed only a small extension from the actual cylinder which is just the tip of the iceberg. The actual cylinder is much larger in diameter. There are two tiny notches in the circular plate which surrounds that extension, which I initially thought were ports for injecting the silicon oil - turns out they are a means by which to unscrew the circular plate/cover and expose the inner parts (cylinder, spring, and also permits removal of the cueing lever). I cut a paper-clip into an elongated 'U' shape, and used it as a tool to rotate that plate/cover counter-clockwise until it unscrewed. After that I just pulled the cylinder out, applied oil to it, and reassembled.
Job done! Will find out tomorrow after the oil settles whether 500,000 cSt is appropriate [Thanks
@Balifly !], but so far so good - the arm descends smoothly and at roughly the right speed.
I've had a busy couple weeks; haven't been inside to scope the motor as recommended by
@EngineerNate and JP yet, but I will be getting to that ASAP. Still a bit confused about how w&f could test normal while the strobe is wobbling... But I have a renewed sense of optimism, and am as determined as ever to get this turntable ready for reliable daily use!
