petehall347
the brandy coffee man
sounds like its proper dead now then .
I didn't see any smoke, but I smelled burning silicon, so probably the LCD chips.I remember when I was looking in to repairing a 90s JVC receiver i had the unit on and acidently let the circuit board that had the speaker terminals sit on a metal surface basically shorting every thing out. Needless to say there was a lot of smoke and there was certainly no getting that thing back to life.
That's what I'm thinking sadly. I guess you learn from being stupid.sounds like its proper dead now then .
i manage to do it sometimes and i should know better .That's what I'm thinking sadly. I guess you learn from being stupid.
Yeah, me too. I'm just now getting into the stereo stuff. I've been into electrical engineering in general since 8th grade and have learned a fair bit in the two-three years it's been since then, I honestly forget. But I've shorted stuff out like this plenty of times when I was first starting with powering my first LEDs with a 9v and stuff like that. Shorted and put too much into nearly all 20 of my LEDs that I had at the time. In this case I was rushing and not thinking though.i manage to do it sometimes and i should know better .
Well before I consider this reciever dead I'd like to properly wire it and see if I get any display then that way I'm not scrapping down something I can save and is worth saving.i manage to do it sometimes and i should know better .
I am surprised to say the least. I just tore it all apart, saw no visibly dead components, put it back together and spent more time in the ribbon cables. I then plugged it in and pressed the power button and it worked! Now I get to play around with the preamp to see of I can get some better output from it. Should I check the opamps? Or just the caps? Andything else I should look for?Well before I consider this reciever dead I'd like to properly wire it and see if I get any display then that way I'm not scrapping down something I can save and is worth saving.
Not as it should be, just as it was when I got it. And I will after I fully wake up and eat a thing or two.So the display is working OK now? I would start by seeing if there is a signal at the tape monitor outputs (REC OUT) first.
I wouldn't just start replacing parts like op-amps.
BTW, let's see a picture of this beast. Silver or black?
Ouch!While I was doing this I managed to miss arrange the ribbon cables. Therefore I put -90v through the +5v rail, most likely killing the smd chips that are no longer made for the display. I figured this out by taking this cable out and shocking myself with it and wondering how 5v could shock me. I also shorted the ground to the pin next to it and it sparked and melted the wire and the problem on my multimeter. I'm glad I didn't touch that one.
I'll get some pictures later today, and silver. I actually really like how it looks though I don't like the lack of actual dials for the volume.So the display is working OK now? I would start by seeing if there is a signal at the tape monitor outputs (REC OUT) first.
It's actually working just as it was before I did that surprisingly. Either way I don't have money to actually get it professionally repaired.Ouch!
May I suggest you just send it to a good tech. I did something similar on my first JVC-7050 power amp, miss aligned a plug and ended up causing a bunch of problems. In hindsight, I would have saved a lot of money if I had just given it to my tech instead of causing more and costly problems.
Good luck!
This is actually a lot of what I've been looking into. While I'm sure I know some stuff in this I know for a fact I do not know nearly as much as I'd like to. I'll definitely look at this once I get a chance. Thanks!If you are really interested in repairing electronics or studying Engineering, you should learn some electronic theory. The Art Of Electronics is an excellent book, written in conversational English, that tells you basically everything you need to know about electronics. You can download the pdf FREE here: http://www.csun.edu/~acm31201/Old Class Work/ECE 340/The Art of Electronics - P[1]. Horowitz, W. Hill.pdf
Are there any AKer's in your area that also do tech work?It's actually working just as it was before I did that surprisingly. Either way I don't have money to actually get it professionally repaired.
Yeah I understand, but I bought this knowing I'd have to fix this on purpose. I'd like to get the experience and a new receiver out of this. I'm less concerned about having it and more concerned with fixing it. I understand what you mean though.Are there any AKer's in your area that also do tech work?
Aker Tom B has fixed several pieces for me at very reasonable prices.
I'm not trying to dissuade you from digging in and doing it yourself, but I went down that road for a bit, and for me, it ended up being much better with a knowledgeable electronics tech to do it and for the piece to be reliable.
Have fun and be careful with the voltage!Yeah I understand, but I bought this knowing I'd have to fix this on purpose. I'd like to get the experience and a new receiver out of this. I'm less concerned about having it and more concerned with fixing it. I understand what you mean though.
I try to be, doesn't always work though lol. Thank you though.Have fun and be careful with the voltage!
