I have heard that the earlier ones used Butyl rubber and then they switched to foam.hifi_nut said:I don´t think the woofers in the 107´s use foam surrounds.
I don´t think any of Kef´s woofer units do, for that matter, they all seem to be some sort of rubber.
Jorge
Hi Luckyman,Luckyman said:I had my woofers redone about 3 years ago in my Kef 107's. I sent them out to Regnar
In Medford NY. Fantastic job, I highly recomend them! Be sure to allow them sufficient
break in time. When I first reinstalled them, I was very disappointed in the bass response.
After a week or so, Iwas in Audio Heaven!
Well...at the risk of implying you don't know what you are talking about. I hold in my very hand a KEF 107 woofer with rotten foam. There are three others sitting a few feet from me, two of which need new foam very badly. None of which have rubber surrounds.hifi_nut said:At the risk of becoming a pain in the ass, I must insist on the fact that I doubt the 107 had foam surrounds.
Luckyman said, and I quote "I had my woofers redone about 3 years ago in my Kef 107's." Redone doesn´t necessarily mean refoamed.
OTOH if there are butyl, or other kind of rubber surrounds, available for redoing the drivers, I don´t have any reason to doubt it could be done at home.
Jorge
if all they need is foam replacement then why have them reconed?tom1356 said:I'll be sending them to Regnar for reconing at $176 each including epoxying the magnets.
Thanks
Tom
They have foam around the outside like normal and a foam "surround" where the dust cap should be. I can't get the parts to do the inner foam. Regnar only does recones on these drivers.dingus said:if all they need is foam replacement then why have them reconed?
Any idea where to get the inner doughnut looking foam?ron-c said:The KEF 107s use a grey foam surround. Changed many of them back in the day as they would blow with about 500 watts or so!
Thanks,
Ron-C
Regnar is going to do a full recone for $176 each and yes it is a whole lot of money especially since there are four woofers. I'll pm Gordon.dingus said:have you tried other sources for the repair (perhaps AK's own Gordon W)? thats an awful lot of $$ for a refoam.
Jorge,hifi_nut said:My apologies Tom1356.
It looks as though I didn´t know what I was talkig about. I stand corrected.
Jorge
