Too small. A 1µf would be a minimum. I'd suggest a 2.2µf cap. Rated for 250V.DanTana said:So, let me gets this correct, putting say a .01 uf 100v cap across the + and - terminals of the power supply caps will effectively keep ESR down to very low levels? I would imagine then using a good metallized polypropolene cap is the ideal choice in this situation? I think I would like to try this on a couple of my amps and see what the results are.
And a metal polypropylene is fine here. Certainly you can get away just fine with a cheaper metal polyester.
The Panasonic ECQ-E(B) is a 250V metal polyester. The Digikey PN for a 2.2µf is P10983-ND, and they are $1.31 each, or 10 for $9.84.
For contrast, the cheaper of the Panasonic metal polypropylene, the ECWF(L) in a 2.2µf 400V are $3.00 each, or 10 for $25.76. The premium metal polypropylene, the ECWF(B) in a 2.2µf 250V is $4.60 each (!) or 10 for $39.39.
These are not 'really' signal path caps, and the expensive ones are really unnecessary unless you just have cash burning a hole in your pocket. The metal polyester caps are peachy here.
