Kenwood KA 9100
You haven't given us much information to go on. What have you troubleshooted so far?
Some questions that would be helpful for you to answer:
  • Is this a brand-new problem?
  • Did you change anything in your setup before this happened?
  • Have you checked with both speakers AND headphones to eliminate one of those as the issues?
  • Are all your cables snug and secure?
  • Are the VU meters moving when you feed audio into the receiver?
  • Have you tried all the inputs to determine whether it is just one source that's not providing output (tape, phono, radio, aux), or all sources?
  • You sure you have the correct speakers selected on the front panel?
  • Have you accidentally engaged the tape monitor?
  • Have you cleaned all the pots and switches with DeOxit to see if that helps?
  • You asked if a fuse had blown. We would have no way of knowing based upon your vague description. Did you try replacing it and see if that solves the issue?
There are internal fuses but that means the reason the fuse blew needs to be determined prior to just switching it back on again with new fuses in place. It could be done with a dim bulb tester in the AC line feeding the amp to prevent further damage if the reason for a blown fuse is unknown.
I think it was working when I stopped using. That was around 2005. I put the tv audio out on all of the inputs. I checked the tv out and audio to my head set. I have not opened it up. I bought the amp new in 1978. I could have had electric overload fron a lightning strike close to the house. I was not using but it remained plug in.
OK, so you bought it 45 years ago, and it's been sitting for nearly 20 years unused, is that correct?
After this many decades without regular use, service or cleaning, you could have a number of issues: leaky capacitors, bad solder joints, blown fuses, oxidized pots, etc.
I mean, without seeing the physical unit first-hand, it would be hard to diagnose.
Really, what it likely needs is a good service and thorough cleaning from a qualified repair technician to get it back in working order.
.. what it likely needs is a good service and thorough cleaning from a qualified repair technician to get it back in working order.
I agree with @benricci let us know where you're at and hopefully we can point you in the right direction of quality repair shop.
You have a very nice amplifier on your hands and if it were me I would get it serviced so that's back up and running in tip top shape
Do you hear a “click” after about 3-5 seconds after you turn it on? Hopefully it’s not an output module issue, “click” is good.
If you hear a click then it might just be something very simple like a tape monitor / processor loop switch turned on or something. You might want to double check all of the basic stuff like input / output connections, pre/main separator switch, cables and function switches first before you take it in for service. Click generally means she’s ready to go and waiting for an input signal. Do lower the volume before clicking switches though, especially with headphones on. Lower volume, flip switch or move cable then slowly raise volume so you don’t blast your ears. Try it with speakers too, you might have a dirty headphone jack or similar.
Got the turner out hooked it up. Moved the switches and the volume control. I got the right meter to show an output. But will not stay on. After moving the switches it comes back on. But no sound from the speaker.
How is the best way to clean the controls? Can I just remove the screws for the front panel to expose the controls? And, what is the best product to use?
Oxidized controls can cause all types of problems. Be warned...this amp is a beast to work on and to really deoxit the controls on this amp requires a lot of disassembly. If you haven't already, work all the switches and pots while listening. if you get some sound it might just need a good cleaning. I had a really nice one that Echowars held my hand on while restoring it. They are really sweet sounding and a bit of eye-candy, too. Good luck.
