mmMmMmMm, that tastes really good. Congratulations! I can't even imagine what how that will transform when the first coat of oil hits it, wish I could be there. That right there is a spectator sport for me.
Biggles
very nice work Glenn. Curious if you will do anything about the separation and if so what. Inject glue with sawdust and hope for the best?
Oh, tasty tasty progression. Question: What's your method for feeding epoxy wood slurry into the the small crevasse?
Am on hold over here for oiling, too hot. It was 96 in the shade yesterday. Such a shame cause I have 2 projects out ready to go. Hotter today and again an uptick for tomorrow. Good for naps and tv.
Biggles
A little bit of epoxy with sanding dust to make it somewhat thick viscosity, or the JB Weld Kwikwood with sanding dust to darken it some, which I did on the first cab with decent results. Still debating which way to go. Either way it's the bottom, so you won't really see it. Mostly for my anal self to make it disappear best as possible.
It's been hot here in NY as well, low 90's last few days. My basement/cave is nice and cool!
Glenn
Hey Glenn,
Gotcha. Am still working on some of the finer points of doing such things. I'm pretty darned okay for most processes though. My downfall is that if I struggle with it for 2 days, my Care Factor goes away. Or if the process sucks all the joy out of the project, I lose interest in any anal processes. Ahem.
I ain't go no basement! Still doing all refinish work outside, under awning. It was 85 degrees when I put that first coat of oil on the AR project. Oil was tacking up and had to be wiped off at exactly 20 minutes. Man, I had to work at getting the excess off, FAST. Fooey.
Biggles
I'm a patient dude! Just can't help it!
When I apply oil, I use an old sock, or part of a T-shirt. Never brushed it, just too much! The applications are very thin, so that's why I need 4-5 applications minimum with light sanding between applications. Makes for a baby butt smooth surface!
Glenn
Hey Glenn,
I use a brush, but you have already seen that in my threads. By the time I brush on one application, I start over immediately because it's all soaked in. Even with my heavy handedness on the oil, I'm doing a standard of at least 5 applications. The 1957 University corner is at 5 applications right now and from the looks of it, I'll end up doing another 2. The oil didn't start sitting on the surface until I hit 4 applications.
I'm justifying the extra oil applied thinking it might give the failing veneer some stability. The veneer on the AR project is so old and soft it nearly blows away on its own, by hand or by power sander. But I don't really know.
I haven't picked up the super ultra fine sand paper yet. I'm getting there!
Biggles
I usually use the 600 grit between applications. It almost acts as a polishing compound.
Great job and documentation as always Glenn. It won't be long before they are displayed amongst your others. I have been following along with your 23's but I wonder how many AK members do this type of veneer work on their restorations. It is very tedious work but rewarding when completed, wouldn't you agree.
Yes! I read that earlier in your post and can hardly wait to try it myself. The results I've received from the ultra fine steel wool have been stellar. But am always looking for a different/better/upgrade to what I'm already doing. I started out with a scotch brite pad, but the results were really lackluster.
Thank you sir!
Biggles
