How much?
Is it working?
Hell...I'm a whore...I'd buy it just to work on it and maybe rersurrect it.
Working or not I'd buy it.
$40?
Any shipping involved?
Sometimes that can kill a deal.I'll say this much its a handsome SOB!
Pictures? How about this:Kenwood KR-4600
FM/AM stereo receiver with FM range: 88-108Mhz and AM: 540-1600kHz. Possibility to choose A, B, A+B or off mode. Bass, treble, balance controls. Signal, tuning and FM Stereo indicators. Also available High Filter and Loudness control. Wooden side panel. Big display. Headphones jack. Input selector for AM, FM, Phono 1, Phono 2 or AUX.
Kenwood KR-4600
FM/AM Receiver
Power Output: 30 watts per channel minimum, RMS at 8 ohms from 20Hz to 20,000Hz with no more than 0.5% total harmonic distortion.
Both Channels Driven: 32 + 32 watts 8 ohms at 1,000 Hz 34 + 34 watts 4 ohms at 1,000 Hz
Total Harmonic Distortion: 0.5% at rated power into 8 ohms 0.07% at 1 watt into 8 ohms at 1,000 Hz
Intermodulation Distortion: 0.5% at rated power into 8 ohms (60 Hz : 7 kHz 4 : 1) 0.2% at 1 watt into 8 ohms
Power Bandwidth: 7 Hz to 35,000 Hz
Damping Factor: 40 at 8 ohms
Speaker Impedance: Accept 4 ohms to 16 ohms
Input Sensitivity/Impedance/Signal to Noise Ratio (IHF A Curve):
Phono 1: 2.5 mV/50 k ohms/70 dB
Phone 2: 2.5 mV/50 k ohms/70 dB
AUX: 150 mV/45 k ohms/90 dB
Tape: 150 mV/45 k ohms/90 dB
Maximum Input Level
Phono: 170 mV (RMS) T.H.D. 0.1% at 1,000 Hz
Output Level/Impedance
Tape REC (Pin): 150 mV/100 ohms
Din: 30 mV/80 k ohms
Frequency Response
Phono: RIAA Standard Curve ±0.5 dB
AUX & Tape: 20 Hz to 50,000 Hz +0.7 dB -1.2dB
Tone Control:
Bass: ±8 dB at 100 Hz
Treble: ±8 dB at 10,000 Hz
Loudness Control (-30 dB): +8 dB at 100 Hz, +5 dB at 10,000 Hz
High Filter: -10 dB at 10 kHz
FM Tuner (IHF):
Usable Sensitivity: 10.3 dBf, (1.8 /A/ at 75 ohms)
50 dB Quieting Sensitivity
Mono: 14.8 dBf, (3.0 mV at 75 ohms)
Stereo: 36.6 dBf, (37 mV at 75 ohms)
Signal to Noise Ratio at 65 dBf
Mono: 75 dB
Stereo: 70 dB
Muting Threshold: 12 dBf (2.2 mVat 75 ohms)
T.H. Distortion at 65 dBf
Mono: 0.15%
Stereo: 0.25 %
Frequency Response: 20 Hz to 15,000 Hz +0.5 dB, -1.5 dB
Capture Ratio: 1.5 dB
Alternate Channel Selectivity: 80 dB
Spurious Response Ratio: 85 dB
Image Response Ratio: 85 dB
IF Response Ratio (balanced): 100 dB
AM Suppression Ratio: 65 dB
Stereo Separation: 40 dB at 1,000 Hz, 35 dB at 50 Hz to 10,000 Hz
Subcarrier Product Ratio: 40 dB
Antenna Impedance: 300 ohms balanced & 75 ohms unbalanced
FM Frequency Range: 88 MHz to 108 MHz
AM Tuner:
Usable Sensitivity (IHF): 20µV
Signal to Noise Ratio: 50 dB
Image Rejection: 45 dB
Selectivity: 35 dB
IF Rejection: 35 dB
Power Requirement: 60 Hz 120V or 50/60 Hz 110-120/220-240V switchable
Power Consumption: 230 watts at full power
Dimension (W x H x D, mm): 500 x 140 x 332
Weight: 23.4lbs (10.6 kg)
