Krell FPB 600 Value?
Infinity!
Well-Known Member
I am looking to purchase a recapped Krell FPB 600 for $3,499 in near perfect condition, is this a fair price? (I'm new to Krell)
That's the thing about these amps, given the sound quality, build quality, overall performance by current standards, and original 1997 purchase price(MSRP $12,500.00)..................... These are some of the truest bargains to be had in the world of amplification, it's still a high end, TOTL amplifier with very few peers.
To echo damacman's sentiments, it won't be for sale for long at that price.
If it's local, that's also a significant bonus as the cost for crating and shipping(182 lbs) that beast will be far from peanuts.
From the info I have been able to find online, it seems like $3,500 is a pretty decent price. I am so excited to hear and most likely buy this amp. I'm going from an Adcom to a Krell, and everyone states it will crush my Adcoms on pretty much every level! :D
Dude ... OMG ... you don’t have your wallet out yet?
The amp is currently getting re-capped and should be done here in the next week. He said that I am first on the list (thank God!!) and will call me once it is done. It is 3 1/2 hours away, so as soon as he gives me the green light that it's done, I'm going to be going on a road trip with my brother, friend, and myself. This is kind of the first 'hifi' component that any of us have bought!
You're gonna feel like you found a hemi cuda in a barn ...
It's gonna need a better outlet and AC mains run than was adequate for the Adcom.
Driven on a toneburst equivalent to peak program duty at 8 ohms, it reached to touch the 1kW line, while at 4 ohms it attained 1.85kW, and for 2 ohms 3.53kW. And for 1 ohm—wait for it—an amazing 6kW! These are single-channel results, but, measured as short-term ratings, they should be available from both channels simultaneously.
This amplifier obviously needs to be used with some caution. While it is well known that loudspeakers are more readily destroyed by smaller amplifiers when overdriven, the fact is that the FPB 600 sounds very clean when run loud—it's all too easy to reach life-threatening levels for your speakers! Further, while I found the plastic-shrouded binding posts a nuisance, I'm well aware of the relatively high voltages this amplifier can provide. In clip, the AC level on the output terminals was 86.4V RMS. Some thought should be given to the other end of the speaker cable; perhaps it should be shrouded in insulation, except at the point of contact to the speaker terminal.
The FPB 600 can vaporize some of the smaller speaker cables if inadvertently short-circuited at the speaker end. I measured a huge peak current of >115A into 1 ohm and stopped there, though more might well be available. If you give up listening, you could always use the amplifier for welding!
It sounds like a bargain to me. I particularly like the power output results in the stereophile review... :)
"The '600 matched this achievement by measuring 945Wpc continuous into the same load (935Wpc into a scaled 8 ohms). This is a huge output, well nigh on 30dBW, and sounded it! Rated output level is 28dBW, 600W, 8 ohms—and this amplifier could hold to this level at all loads and frequencies, 20Hz-20kHz, 8 ohms down to 2 ohms.
I wasn't able to run my long-term continuous testing at 2 ohms, but compromised with five-second bursts—long by peak-measurement practice (eg, 20ms). The FPB 600 could sustain a 29.3dBW level into this load, corresponding to 3.4kWpc—an extraordinary figure.
Driven on a toneburst equivalent to peak program duty at 8 ohms, it reached to touch the 1kW line, while at 4 ohms it attained 1.85kW, and for 2 ohms 3.53kW. And for 1 ohm—wait for it—an amazing 6kW! These are single-channel results, but, measured as short-term ratings, they should be available from both channels simultaneously"
IIRC, somebody arc welded with a big Krell once in a review. Congrats, it’s a true beast!
I have a couple of them I picked up last year, but due to the electrical requirements have not hooked them up yet. Bought a scissor jack cart just so I could move them by myself. Will be interested in your hearing impressions when you get it all setup.
Picked up a couple!? How many Krells do you have?? lol Well, I just checked and my whole house runs on 20 amp breakers (what krell recommends). Now, I just need to call an electrician to see how much it would cost to put a direct line in! :dunno:
Those are staggering numbers by any standard ... wow!
End game amp for sure. For that price I'd be all over it.
Definitely post some impressions when you get it all hooked up.
That is a steal if it has been completely recapped. That alone costs about 2K. Minimum line should be 30amps if it was mine. I have 4 Krell Mono blks in my listening room MDA500's and KMA400's and the room gets HOT.
This is a great stereo amp and will need the best associated equipment to be used with it for your audio nirvana. Be careful not to smoke your speakers
4 MDA’s!!!! What do you power them with? A reactor?! Lol. Must sound great and no need for heating in the listening room. Heck, my KSA 250 warms up the whole basement!
