Brett a
~◦●○o0o○●◦~
As many of you may know, I recently moved from a lifetime with floor-standing speakers to a pair of stand-mounts (Focal 807Ws). I just fell in love with their imaging and transparency. So much so that i was willing to give up that bottom octave.
But I'm nothing if not restless and I don't think it took 2 weeks before my mind went to getting a sub. The sub that matches my speakers is too expensive for me to buy any time in the near future. ($1,500) and I've been told that it's really nothing too special anyway.
So after considering buying an SVS and looking at DIY, I finally decided to learn about DIYing a sub and build not just one, but a pair of sealed units myself.
That whole precess played out in this thread: Subwoofer: Buy or Build?
Long story short, after a lot of reading and planning, I decided I wanted to build a pair of sealed passives and run them with a single plate amp. So this meant looking at 8 ohm drivers to share one 4 ohm amp.
After looking at all the offerings at Parts Express, I was intrigued by a set of Lambda 12" 8 ohm drivers off eBay.
I somewhat hastily pulled the trigger w/o really grokking the implications of these drivers needing a lot of cubic feet to flatten out in. More on that a few posts down.
Anyway, here are the drivers:
Lambda SB12-8:
Lambda SB12-8:
The Lambda SB12 driver is designed for sealed enclosure.
It has a high Xmax, stiff poly cone with stiff poly dustcap, coated and sealed foam surround,
12 spoke aluminum basket, dual stack 120oz magnet, gold binding post, military spec coatings and
glues. It is a high excursion, very low distortion, super tight bass driver.
Recommended maximum crossover point is 500Hz, rated power handling is 500W. 2.83VSPL = 88.6dB
Specs
Motor : PL (overhung)
Magnet : 3.4Kg Ceramic 5
VC diameter : 51mm
VC Former: Black Anodized Aluminum
VC Wire: 2 Layer Copper Roundwire
Basket : Cast Aluminum 12 Spoke
Cone : Mineral Filled Hard Poly
Surround : Doped Foam, 2 layer treatment
Dustcap : Hard Poly
Spider : Hard stiffness Nomex
Faraday : Copper
Terminals: Gold Plated Binding Posts
Weight : 10 Kgs
Fs : 20.9 Hz
Qms : 4.23
Qes : 0.64
Qts : 0.56
Vas : 160 Liters
Cms : 0.4 mm/N
Mms : 145 grams
Sd : 531 cm2
Rms : 4.5 Kg/S
Pe (nom) : 300 Watts
Pe (max) : 500 Watts
Pe (transient) : 1000 Watts
Air Gap : 14 mm
VC Length : 38 mm
Linear Xmax : 14 mm (peak)
Mech Xmax : 20 mm (peak)
