Large Advent Masonite Rings
ENGRF
Hi,
I took out the masonite rings on a large advent and noticed them not to be flat, they are a bit tilted upwards on the inner side. Is this normal or aging did this to the rings? Should I make new rings?
THanks
Hi,
THanks
It is not normal, I found that to happen on a few that did not have much glue holding them to the frame. The glue, construction adhesive, should run about .25" in from the outer edge, this combined with clamping it flat helps if you want to reuse them. Still may not be perfect, but at least improved, I discuss the issue here, post 10:
http://www.classicspeakerpages.net/IP.Board/index.php?s=&showtopic=2931&view=findpost&p=67719
Pete,
I did notice lack of glue on the metal frame. Actually I wasn't trying to get the ring off but one end came loose while picking it up so I took it off completely. Thanks for letting me know that it is not normal. This is my first masonite ring repair so did not know how it should be. I might make new rings, the old ones would be hard to straighten I guess...
Thanks again...
New ones shouldn't be hard to make using the old ones as templates.
I would use tempered masonite.
EDIT: I forgot, I have seen this too and, being that the inner edge wasn't raised too much, I just used them as is and it doesn't seem to affect much of anything.
Theoretically, of course, it would move the surround and, in turn, the cone further forward. The spider still has more control though.
Doug
