Leestereo's Restoration/Upgrade of a Sansui AU-719
What is the reading you get on the driver boards? Have you confirmed that the connections to boards are correct?
Excellent write up. I acquired my AU-719 not to long ago and I followed some of your restoration to get her running and sounding very good. I just need to replace the trim pots on the driver boards.
Excellent piece of work. At the moment I'm working on a 719. Why is this upgrade only about caps and a few resitors? What about the transistors (2sc1313 for example)
I Just picked up a 719. I have never heard or restored one.
I powered it up and, although it has some issues, it sounds tight.
Working on a 719, with a messy glue issue. What would be a good replacement for the ZD-01? It has corrosion creeping up to the body...
