thedelihaus
Nocturnal transmissions
Is your Sumiko the one with the top and bottom locating pins?
It has adjustable azimuth and is badged Sumiko- that is all I recall. I think it's just one set of pins- not 100% sure.
That is great news. I always thought the PL-41 was way under rated but not to the extent that it could hang with a Linn. I think I am going to pull my bearing and repolish it the way you did; you were way more thorough. Where do you buy micromesh? I wonder how that Benz would sound on my modded PL-41 :scratch2:
I have been playing the PL-41 more today...so after playing it for a while I took my trusty stethoscope to it and heard a small ticking sound, along with just the sound of a machine running...it's kind of hard to describe, but I attribute that to the unpowdered belt making noise as it travels...pulled off the motor cover, and noticed that the ticking occurred when there was a smudge on the belt passing over the pulley...so, I pulled the belt off and washed it...I found a tiny little bit of schmutz on the belt and started scrubbing it a bit more...took some red Scotchbrite to it, yet still there was a small perturbation in the surface of the belt...so I started cleaning it with MG Chemicals Rubber Renew..still there was the small area that could have been where the belt had one time sit on a pulley and not moved for quite a while...
So, I went through my belt stash and found one that was slightly smaller in diameter and slightly smaller in width...I scrubbed it with soap and water and the Scotchbrite, and cleaned it with the Rubber Renew...the belt' surface felt perfect, so I douched it well with talcum powder, installed it, let it turn a few revolutions and once again listened with the stethoscope...
Silence!
Total silence! On both the plinth and the top plate! This was a big change from just a few moments before! None of the running noises I heard before were there...so, this helped prove to me that the talc lets the belt grab and release the platter without any kind of stiction that causes noise..it worked!
Getting rid of a tiny hard spot in the belt by replacing the belt got rid of the ticking sound, too...
There's just no noise now even though this belt is a bit more snug than the last one...maybe there's a belt made from 1/4" recoding tape in its' future...strobing it also proved the speed to be spot on, thank goodness!
Please note, if you talc a belt make sure the powder you use is 100% pure talc and does not have any baking soda in it!!! Clubman Talc is real talc so that's what I always use...the baking soda will screw up aluminum, is hygroscopic, and just does not work right in comparison to the real thing...
Just more observations on my old beast.
I use clubman talc as well. How do the rubber grommets that hold the motor on look?
Well
All this has got me going again, im going to re polish my spindle just because.
Im looking for a good shop that can mill off the ridge on the platter.
No luck so far but im looking.
A PL-41 against a Linn, wow! guys it looks as if were really on to something here.
